Old 11-26-2006, 12:47 PM   #1
amloya
6 bolt vs 5 bolt wheels
I recently bought a 1970 c10 Custom that came 6 bolt wheels. I am planning on converting to disc brakes - front and back. Any advantage of 6 bolt vs. 5 bolt wheels?
amloya is offline   Reply With Quote
Old 11-26-2006, 12:51 PM   #2
pimperout
pimperout's Avatar
Re: 6 bolt vs 5 bolt wheels
4x4 or 2wd i know i have a 70 gmc 1500 and its 2wd with 6 bolt pattern and i was told they do not make disk convertions for 6 bolt 2wd so as far as i know you need to find a 2wd 6 bolt with disks or you may be able to get them off of a 73-87 possibly
pimperout is offline   Reply With Quote
Old 11-26-2006, 01:11 PM   #3
amloya
It is 2wd. Thanks piperout.
Old 11-26-2006, 01:44 PM   #4
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
You can get disk conversion for 6-lug from ECE or CPP. As for advantages of one over another? 5-lug IMO has more choices for aftermarket wheels.
I have 6-lug on my '67 and have discs up front.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 11-26-2006, 02:40 PM   #5
roj2323
keeping the 6 lug is cheaper since you don't have to change the axles, rear drums, and rims. however like others have said if you plan on changing the rims 5 lug is easyier to find custom and or nicer stock rims.
ondrew
roj2323 is offline   Reply With Quote
Old 11-26-2006, 04:27 PM   #6
corn
Its probably just me but I like the look of the 6 bolt rallies better than 5 bolt rallies. Thats the big reason Im leaving mine 6 bolt...
corn is offline   Reply With Quote
Old 11-26-2006, 07:39 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
a huge advantage to going 5 lug, is you can get rotors anywhere in the country, and there will be a parts store that'll have them on hand. 6 lug rotors are special order.
You can do 5 lug cheaper if you are carefull...with the exception of the bling wheels you may already have... but if you have nasty wheels, and bling is in your future, then it is a moot point.
Old 11-26-2006, 07:54 PM   #8
BarryB
BarryB's Avatar
Getting parts is always a plus. so thats is what I would do. And it really isn't that big a deal to swap it over. IMO. others my think different.
BarryB is offline   Reply With Quote
