Old 11-26-2006, 03:34 PM   #1
crazy longhorn
Fabricate till you "puke"
ART a arms
Who has pics of the top & bottom side of the ART Upper a arms? my ? is are they like a hoop (the tubing) on the balljoint end.....like a 1 pc tube in an A comfigureation ? L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-26-2006, 03:42 PM   #2
jimmydean
jimmydean's Avatar
Re: ART a arms
Here's a shot stolen from the 66swb build up that Porterbuilt is working on.
jimmydean is offline   Reply With Quote
Old 11-26-2006, 07:32 PM   #3
crazy longhorn
Re: ART a arms
Thanks for that pic.....it pretty much answers my ? That looks like a nice stout pc L
Old 11-26-2006, 10:40 PM   #4
mkhutch
Throbbing Member
Re: ART a arms
I just installed the Strong Arms without the body on so if you need a particular shot, just let me know.
mkhutch is offline   Reply With Quote
Old 11-26-2006, 11:10 PM   #5
rancid
rancid's Avatar
Re: ART a arms
where do you buy these.
rancid is offline   Reply With Quote
Old 11-26-2006, 11:23 PM   #6
mkhutch
Throbbing Member
Re: ART a arms
You can get them from Air Ride Technologies directly or I recommend using Nathan of Porterbuilt streetrods. Awesome guy! You also get a 10% discount going through Nathan.
Old 11-27-2006, 10:34 AM   #7
craig@ridetech.com
Formerly LSC71
Re: ART a arms
Just to give you some insight on that question. Originally our Upper control arms were more of the "A" arm shape where there were two separate pieces that came together at the ball joint plate. Now, it is a one piece bend like what you see in the picture above.
craig@ridetech.com is offline   Reply With Quote
Old 11-27-2006, 11:16 AM   #8
crazy longhorn
Re: ART a arms
I thought I saw 2 different "shapes" on the same arm, thanks for setting it straight I am running a 3" spring drop, & just looking to straighten the upper balljoint angles out. I dont plan on bagging it, or changing the lower arms at this point. Are the upper arms compatible with the stock lowers, & what will they change on the front geometry? Are the arms shorter C to C ,balljoint to shaft? L
Old 11-27-2006, 01:23 PM   #9
craig@ridetech.com
Formerly LSC71
Re: ART a arms
The upper arms are compatible with your lowers, there weren't really any changes made to those in the way of geometry, but they should help with your ball joint angles. We did, however, put a couple degrees of caster into the lower arms and made most of the geometry changes there since most guys usually change those arms first.
Old 11-27-2006, 01:39 PM   #10
Tony@AirRideTech
Junior Member
Re: ART a arms
Hello " Mr obvious" ... long time lurker first time poster.....
Tony@AirRideTech is offline   Reply With Quote
Old 11-28-2006, 01:20 PM   #11
crazy longhorn
Re: ART a arms
Thanks much for the input I had planned to modify the lower arms to fit my needs.....unless I ditch the coils. L
