Throttle sticking
I took the 68 for a drive and I noticed that the throttle is sticking. I checked the gas pedal hinge on the firewall and that is not binding up. I checked on the throttle linkage (not sure if that is its name see pic piece is colored in green) and without the throttle rod or springs it is sticking. I sprayed some carb cleaner in there but no luck. Any suggestions?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 Last edited by skokie; 11-26-2006 at 05:17 PM. |
Re: Throttle sticking
maybe lubrication??? if it moves if it pivots lube it // a pretty simple principal
What should I use to lubricate it? Also maybe hit it with some carb cleaner?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
hit with carb cleaner to clean first then either a silicone lube or i like white lithium grease in the spray// also in the cab where the pedal likage pivots and goes thru firewall
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 11-26-2006 at 06:20 PM. |
#5 | |
laying low
![]() Join Date: Mar 2001
Is this a reman'd carb?
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
Well I disconnected the carb springs and throttle rod. With the carb still on the intake I gave it the throttle linkage (area in green) a good cleaning with carb cleaner. When I hooked up the throttle rod I noticed a slight catch. I extended the rod by 1 turn and it looks like that has fixed it.
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 Last edited by skokie; 11-27-2006 at 01:44 AM. |
