Old 11-26-2006, 07:48 PM   #1
oldgmc
oldgmc's Avatar
Head gasket what to use to seal gasket
I know this has been asked many time but a search of the forum did not give me what I was looking for. I am replacing the head gaskests on my 79 with a 350 I have so far removed the right head the one that was leaking. The directions on the package say steel use a sealer otherwise dry. The gaskets I have are felpro and they have a blue coating on them so I would guess dry but they are the same gaskets that are on now and it failed so I am thinking to seal it to be sure they do not leak and was wondering what to use or is it a bad idea and should I just go the dry route. This is not the origional engine a good wrench engine was installed by the PO. Not sure when but the cylinders are clean smooth and no sign of any wear on the walls so seems to be low milage
oldgmc is offline   Reply With Quote
Old 11-26-2006, 08:19 PM   #2
Nolowrider
Nolowrider's Avatar
Re: Head gasket what to use to seal gasket
I don't use anything on head gaskets. I just put them on dry, no problems so far.
Nolowrider is offline   Reply With Quote
Old 11-26-2006, 08:52 PM   #3
OJOE
Crew Cut
OJOE's Avatar
you may want to have the heads surfaced or at least make sure they are not warped. i would not use any sealer. good luck
85 SWB 1/2 TON CREWCAB/5.3
03 CHEV 3500 DURAMAX CREW CAB
85 CHEV SWB/TPI
06 CHEV TAHOE (WIFES)
30 MODEL A HOT ROD
07 HARLEY DAVIDSON BAGGER
09 STREET GLIDE
AN D A LOT MORE JUNK
OJOE is offline   Reply With Quote
