Old 11-26-2006, 09:18 PM   #1
71chevytruckguy
71chevytruckguy's Avatar
WTB:front bearing retainer for 4 spd saginaw
i need a front bearing retainer for a 4 speed saginaw transmission. i think they're the same for the 3 speeds also. its what's pictured below that has the cracks in it. thanks. chris.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 11-26-2006, 10:10 PM   #2
Blue_71
Bloo
Blue_71's Avatar
Re: WTB:front bearing retainer for 4 spd saginaw
i think i have one of those. if i do, ill sell it for $25 shipped. ill look tomarow and make sure its the right one
if you dont mind measure between 2 bolt holes so we can make sure its the right one (theres a couple different sizes)
Blue_71 is offline   Reply With Quote
Old 11-27-2006, 12:14 AM   #3
71chevytruckguy
the outer diameter is 4 5/8", the distance bewteen hole is around 3". im tryin to find one locally casue i need to get one asap. ill check with my junkyard guy 2morrow and if he has one, if not i'll take yours if its the right one. thanks. chris.
Old 11-27-2006, 10:09 PM   #4
71chevytruckguy
couldn't find one at the junk yard so if the on you have is the right size, ill take it. thanks. chris.
Old 01-28-2007, 03:47 AM   #5
Blue_71
Bloo
Blue_71's Avatar
i know this was 2 months ago, but if you still need this, i found it when i was cleaning out the building. let me know, ill get pics tomarow (sunday jan 29)
Old 01-28-2007, 04:33 AM   #6
71chevytruckguy
got lucky and found one from one of the local short trackers and the truck's back on the road. thanks. chris.
Old 01-29-2007, 12:50 AM   #7
Blue_71
Bloo
Blue_71's Avatar
sounds good to me, glad ya found one! sorry it took me so long to find this one
Josh
