Old 11-26-2006, 09:24 PM   #1
dan468
dan468's Avatar
Question for 68 pickup owners...help!
Does anyone have a picture of a factory 1968 firewall on the driver's side? I am in the process of shaving my firewall but can't remember what all the holes on the driver's side go to. I have three holes, one is speedo and a second is oil pressure. Can't figure out the third. Please help!
Thanks Dan
dan468 is offline   Reply With Quote
Old 11-26-2006, 09:34 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Question for 68 pickup owners...help!
Check this thread out....
http://67-72chevytrucks.com/vboard/s...firewall+holes
LockDoc
Leon
Old 11-26-2006, 10:10 PM   #3
qksilver
emergency brake cable?
qksilver is offline   Reply With Quote
Old 11-27-2006, 01:04 AM   #4
dan468
dan468's Avatar
Lock Doc thanks for the thread, however, the pic is for a 72 and very different. Qksilver the E-Brake is a rectangle on the bottom of the cab, i found that one thank goodness.
Old 11-27-2006, 12:59 PM   #5
Bob Moore
Do you still have questions? Size and location would help.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 11-28-2006, 09:38 AM   #6
dan468
dan468's Avatar
Yes I still need help. The three holes I mentioned are on the very driver side of the fire wall. they are above the sqaure hole for the wiring block. One I believe is for speedo, and I'm guessing one could be for a choke?, and the third I'm lost on. Thanks for the help!
Old 11-28-2006, 09:54 AM   #7
panhandler62
Java Mechanic
panhandler62's Avatar
I have a 68 C-20 ... but I'm at work... I'll have a look when I get home.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 11-29-2006, 06:12 PM   #8
panhandler62
Java Mechanic
Here is a picture of my firewall:
The black cable that is going nowhere is the choke.
Keith
Old 11-29-2006, 06:42 PM   #9
msgross
msgross's Avatar
Mine has three holes left of the wire block, lower is for my Tach wire, middle is speedo, top is plugged off. Then there is a small hole above the block that has a rubber nipple in it (no idea on that one). My oil pressure goes in on the back side of the hump, along with manual throttle.
msgross is offline   Reply With Quote
Old 11-29-2006, 09:47 PM   #10
dan468
dan468's Avatar
thanks guys, looks like everything but the oil pressure and the speedo is getting the electric treatment.
