Old 11-26-2006, 09:44 PM   #1
Draggn66
Wrenchin & Sandin!!!
Draggn66's Avatar
Vent window question
Well I got my doors painted this weekend and was replacing all the rubbers but the vents cause it look like too much trouble to get them out. But....I ended up removing them cause the window was out of the track so I guess I should replace those seals also. How hard of a job is it and can the vent windows be put back on with the doors on the truck? I really want to get the doors on instead of waiting for the seals to come and install them. Any advice would be helpful. TIA.....
Randy
Shorewood, IL.
My Favorite eBay Searches
My Driver Restore Thread
1971 C10 Longbed
2005 Silverado Shortbed
2005 FXDWG
Draggn66 is offline   Reply With Quote
Old 11-26-2006, 09:52 PM   #2
Aarons72s
Re: Vent window question
Yes the vents can be installed with the doors on the truck. Now putting a new seal kit in the vent window is another thing. If you are just replacing the center felt division bar, that is pretty easy but if you are doing the actual rubber that goes around the wing window glass, that is a pita. You have to drill out rivits to get the window apart. So you will ahve to order the rivit kit also. Hope this helps.
Aarons72s is offline   Reply With Quote
Old 11-26-2006, 10:03 PM   #3
Draggn66
Draggn66's Avatar
Well at first I was just changing the window channel and the division bar felt. But since I have the vents out I guess it would be a good time to change those seals also. I'm gonna order from GMC Pauls to get the 10% deal so I'll order the seal kit and the repair kit. Just how much of a pita is it? Do the seals come with instructions? Anyplace I could see the step by step?
Thanks for the reply
Randy
Shorewood, IL.
1971 C10 Longbed
2005 FXDWG
Old 11-26-2006, 10:10 PM   #4
Aarons72s
Im not sure if they come with instructions. I thought about doing mine until reading and looked at mine and said screw it. I think it is mainly a time thing. Hopefully someone hoo actually has went all the way and done it will chime in. I am just going off of all the experiances I have herd about. Sorry cant be more help then that. I dont know if there is an actual faq on this subject or not.
Old 11-26-2006, 10:17 PM   #5
72CSTC5
72CSTC5's Avatar
It is a major pain in the butt. Good luck.
72CSTC5 is offline   Reply With Quote
Old 11-26-2006, 10:19 PM   #6
Jayss109
Active Member
Jayss109's Avatar
I used standard rivets that hold in the chanel felt etc. The pivot for the window is a different story. I standard rivet WILL work, but it will be loosey-goosey.
As for the rubber seal... it is A PAIN@@!! I did the drivers first, and it works...no whistles/leaks, but its tight and the outer part that lays down onto the door never has sat down perfect. Surprising it doesnt leak there.
The passenger went alot smoother, everything fits good and lays down good, but it whistles sometimes.
I would not choose to ever do it again. Id much rather pay the $$ and get them already assembled and new.
Jason
________
HERBAL VAPORIZERS
Jayss109 is offline   Reply With Quote
Old 11-26-2006, 10:26 PM   #7
Green Machine
Green Machine's Avatar
I've done 2 sets and they never quite work or fit right again. If anyone knows where to get new rubber that actually fits please post here. I heard the aftermarket complete assemblys are not perfect either. Please let us know how the gmcpauls rubber fits.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 11-27-2006, 02:42 AM   #8
Draggn66
Draggn66's Avatar
Thanks for the replies. I'm gonna give it a shot. Hope it turns out ok
Randy
Shorewood, IL.
1971 C10 Longbed
2005 FXDWG
Old 11-27-2006, 02:31 PM   #9
BobRitts
Second that! If your stockers can clean up with some fine steel wool and silicon spray... KEEP THEM! All the aftermarket stuff I've seen is crud compared to the stock rubber, plus, you have to go through all the effort to swap it out (rivets, etc.). If I had it to do over again I would have kept the stock rubber.
BobRitts is offline   Reply With Quote
Old 11-27-2006, 05:03 PM   #10
70GMCer
70GMCer's Avatar
I hate to disagree with most on here, but I did mine and without any problems. You do have too have take your time and only take one side apart at a time. That way, you can compare them. Took me about 30 minutes for each side. I didn't used the rivet kit that is talked about. I just used 1/8th stainless rivets. Worked for me. The only hard part was putting them back into the door. To me, that was a "pita".
steve
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 11-27-2006, 06:55 PM   #11
68jimmy
68jimmy's Avatar
steve
That was the route I went with. Luckily I had another set laying around for reference as I used the glass from one set into another set. I went with the 1/8" stainless rivets and it all came out great. They whistle a little bit but its a 38year old truck, I expect it to whistle and groan a bit... Just take your time, use plenty of silicone spray to get that rubber over the frame and carefully re-install in your doors. There is nothing that looks nicer than clean black rubber around your windows especially if your getting it repainted. Good luck.
78 C10 LWB Super Cheyenne
68jimmy is offline   Reply With Quote
Old 11-27-2006, 10:38 PM   #12
Green Machine
Well then it has to be the rubber used. 30 minutes ? My son and worked on each one about 3 hours going over everything real carefully and they still are not right. I was going to be damn sure these worked nice, but no dice.
Old 11-28-2006, 10:58 AM   #13
davesamnesia
Active Member
davesamnesia's Avatar
Just two cents worth, I haven't done mine yet. If you are going to use silicone spray make absolutely sure you're nowhere near your painting area. Fisheyes suck.
Dave
70 K5 350/350 Air
Dave
davesamnesia is offline   Reply With Quote
