Old 11-26-2006, 10:36 PM   #1
grinch4om
dang its hot
grinch4om's Avatar
rear ends
Hey guys, I'm an old drag racer and an ase master tech, that being said so you know where my heads at. I put a rat in my 84 short bed, 700R4, hooker,wieand,holley etc. and it still has the 10 bolt in it. I know it wont live if the truck hooks, how good are the 12 bolt truck rears? I bought one for $25. Known good, non posi. With a locker or posi in it, will it live? I'm not planing on drag racing, just slappin curbs. I would appreciate any stories or experiences any of you have had with these.
grinch4om is offline   Reply With Quote
Old 11-26-2006, 10:46 PM   #2
leftcoast66
leftcoast66's Avatar
Re: rear ends
Should be good, seen/ done some crazy stuff w/ my 12 bolt and its still in one piece w/ no problems, and honestly never even changed the gear oil since I bought the truck.
leftcoast66 is offline   Reply With Quote
Old 11-26-2006, 10:48 PM   #3
piecesparts
Parts and more parts
piecesparts's Avatar
Re: rear ends
There are those that believe that the Truck 12 bolt is not very strong. I on the other hand, have one in my 84 with a 383 stroker and my son now has one in his truck with a 350 in front of it. Both rear ends are 3.73 geared and has posi. The rear end in my truck is as old as the truck is and is standing up real well with the use that it has had. My Son's truck had a 10 bolt and we put the used axle into his truck out of a 3/4 ton 4-wheel drive truck. We changed out the axles for 5 bolt units. I imagine that you can destroy anything if you want to, but the 12 bolt is working well for us.
piecesparts is offline   Reply With Quote
Old 11-26-2006, 10:54 PM   #4
grinch4om
dang its hot
grinch4om's Avatar
Re: rear ends
thanks guys, most of my experience is with a 9".
Old 11-27-2006, 08:56 AM   #5
Nolowrider
Nolowrider's Avatar
Re: rear ends
Do you have any extra 9" ers?
Nolowrider is offline   Reply With Quote
Old 11-27-2006, 09:10 AM   #6
grinch4om
dang its hot
grinch4om's Avatar
Re: rear ends
not any more but I have access to alot, what do you need? New Orleans? Is there a scene anymore for hot rods?
Old 11-27-2006, 05:29 PM   #7
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: rear ends
As far as stock 10bolt vs 12bolt you aren't gaining any strength by going from 10 bolt to 12 bolt.
The 12bolt Truck is NOT the same as a Passenger 12bolt. The pinion gear is smaller, and therefore "weaker".
The 10bolt has a smaller ring gear ( 8.5" vs 8.875" ) but the ring gear on the 10bolt is larger.
I have had both behind 454's with stick shifts and nitrous, and they both held up fine.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 11-27-2006, 05:37 PM   #8
ocbaud
Garage Queen Material
Re: rear ends
exactly
the truck 12bolt isnt any better than the truck 10bolt.
ocbaud is offline   Reply With Quote
Old 11-27-2006, 05:48 PM   #9
grinch4om
dang its hot
grinch4om's Avatar
Re: rear ends
really!? I'll be. Then what was the purpose of10 verses 12?
Old 11-27-2006, 07:14 PM   #10
ocbaud
Re: rear ends
i'm guessing it was just cheaper to use the 10 bolt since it was used for various other cars, unlike the truck 12-bolt, which was only for trucks
Old 11-27-2006, 07:15 PM   #11
Captkaos
Captkaos's Avatar
Re: rear ends
When comparing trucks, nothing really.
When comparing passenger cars the 12bolt is bigger in both ring gear and pinion. And some 10bolt passenger cars have the 7.5 or the 8.5 ring gear size.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
