11-27-2006, 01:49 PM | #1 |
Junior Member
Anyone Ever?
Has anyone here cut the rear springs and just fabbed up something to hold them?
11-27-2006, 02:39 PM | #2 |
Junior Member
Re: Anyone Ever?
on my 63 belAir I had cut coils and used cable to limit the axle travel..... It was gay but it worked.
11-27-2006, 03:31 PM | #3 |
Re: Anyone Ever?
why not save up and buy lowered springs ... they're about $100 ... you and your passengers safety is worth that ... isn't it?
11-27-2006, 05:38 PM | #4 |
Junior Member
Re: Anyone Ever?
Why spend 100 dollars when you can do it yourself?It doesnt make it any more of a risk if you know what you are doing.Somebody somewhere made the springs that you bought didnt they?Im just not the type of guy that buys something someone else made if I can do it myself.Thats the same reason I dont buy vehicles somebody else has fixed up.
11-27-2006, 08:22 PM | #5 |
Outlandish Trends - FL
Re: Anyone Ever?
The rear springs are tapered at the top and bottom, unlike the front springs in which the coil is the same top to bottom. IF you were to cut the rear spring, you'd have to fab up new spring retainers for top & bottom. They'd have to be pretty big. Take a look at your factory coil and you'll see what I mean. Like Shane said, it's only $100. I'd just do it right the first time. It could turn messy pretty quick if you had one fail on you and pop out of there. I have some 4" drop coils if you're interested. PM me.
-Bret 67 short-fleet sold! |
11-27-2006, 08:43 PM | #6 |
Re: Anyone Ever?
I've done it before but this was back before drop springs were readily available.
We cut the bottom of the spring & dropped it into place on a fabbed up 'cup' that attached to the trailing arm. The 'cup' was basically a piece of .250 plate w/a small section of pipe welded to it that was just a little larger than the O.D. of the coil. The coil simply floated in the cup @ the bottom & was bolted in just like stock on top. The only issue we ever had was when the truck was raised in the air on a lift. You would have to make sure the springs seated back into the cup when you set it back down on the ground. It didn't ride very good but we were poor & my buddy just wanted his truck low. We did this along w/some home-made lowering blocks from .250 wall square tubing.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 11-27-2006 at 08:47 PM. |
11-28-2006, 12:13 AM | #7 | |
Re: Anyone Ever?
I'm just suggesting this in an attempt to save you some time and headaches ... and possible a lot more money down the road versus the $100 you save now. Good Luck. |
11-28-2006, 12:21 AM | #8 |
Re: Anyone Ever?
[QUOTE=SCOTI;1911216]I've done it before but this was back before drop springs were readily available.
How old are you SCOTI???????
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
11-28-2006, 01:30 AM | #9 | |
Re: Anyone Ever?
At that time..... they didn't make drop spindles yet .
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 11-28-2006 at 08:29 PM. |
11-28-2006, 03:08 AM | #10 |
Epoxy Primer Friendly
Re: Anyone Ever?
It's not worth it at all on the rearend of the truck. When you cut the coils it destroys the spring rate completely. It will ride horrible. My opinion.
11-28-2006, 03:25 PM | #11 |
Re: Anyone Ever?
I have never tried this in my truck, but in my Jetta I bought these coil clamps that will lower or raise your car an inch or two. They might work in your truck. I got them at my local auto parts store and paid 10 bucks. You may want to try.
11-29-2006, 11:57 PM | #12 |
Re: Anyone Ever?
Not highjacking your thread but would any of you guy's know a easy way to drop a GMC truck in the rear, it's a leafspring truck 1/2ton??? thanks.....
Things happen for a reason! |
11-30-2006, 12:49 AM | #13 |
Re: Anyone Ever?
How much drop? A flip kit would get you about 5" drop & could be made fairly easy (you could purchase a kit for a 73~87 truck & trim the leaf 'saddles' down since 73~87'S are more commom). There are also de-arched leafs available.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 11-30-2006 at 12:52 AM. |
11-30-2006, 01:45 PM | #14 |
Re: Anyone Ever?
i have fabed up a lot of stuff unless you have the steel just sitting around to make the brackets and cups out of its not worth it cause it wont bee to cheap and with spending the money on steel and the time to make cups and brackets your expence is probley more than what the springs would cost
now i am a big do it your selfer also so i know i have done many things that costed me more money in the long run but it was worth it in the long run for experiance and i enjoy doing it those are my thoghts sogood luck and put pf some pics so we can see it when your done
http://www.cardomain.com/ride/2461088 |
11-30-2006, 03:09 PM | #15 |
Re: Anyone Ever?
We cut our 'cups' from a section of scrap pipe, used scrap for the base that bolts to the trailing arm, & used scrap section of 2x2x.250 wall tubing for the lowering blocks.
The biggest expense was having a local bolt company make the longer u-bolts needed but they were way cheaper than new lowering springs. When you're 16 & responsible for all your own debts.... but only work part-time, every penny counts. The time it took to fab the stuff up was an investment in our 'hot-rodding' education. This same friend also had his hubs re-drilled even though he retained the stock drum brakes so he could mount up a set of car pattern vette ralleys & then eventually some used weld wheels. I never would do this mod to my truck because I didn't like the way it rode (to rough for my taste). My buddy was ok w/it though & his truck sure looked alot 'cooler' than my stock height truck everything else being equal.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 11-30-2006 at 03:10 PM. |
11-30-2006, 05:09 PM | #16 |
Seņor Member
Re: Anyone Ever?
Bruce McCoy... he was absolutely all there was for wound drop springs back then.
11-30-2006, 05:12 PM | #17 |
Seņor Member
Re: Anyone Ever?
I went the other direction and redrilled the rotors to fit Ronal R9's on my S-Jimmy before Ronal figured out that 5x4.75 was indeed a worthwhile pattern to build.
11-30-2006, 05:28 PM | #18 |
Re: Anyone Ever?
its always worth trying something as long as you learn something out of it and if it dosent work out you always have getting new springs as a back up plan i know that i would probly try and cut them before i bought new ones
