Old 08-18-2002, 06:48 PM   #1
chewed 71'er
Door window felt channels
Looking for comments on replacing door window felt seals. Are they difficult to install? Several vendors offer door felt kits, don't know if they're a good buy or not.
chewed 71'er is offline   Reply With Quote
Old 08-18-2002, 07:04 PM   #2
Bill72BB
Thats the Hillbilly way
Bill72BB's Avatar
chewed.
I had no problem installing the window felts on the 72 .
Just remove the door panels ,take out old channels, I started at the top front of the door ,loosely feed the channel down into the door,the only difficult part is getting it past the lowered window inside the door ,I wd 40 the 6-8" of channel and slide it right on and past the glass.
Measure b4 sliding past the glass I think I had to trim some off.
Good luck Bill
BILL
Torrance Calif 90504
Member DUF Club
Member Old Farts Club
72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts
tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion.
" If I knew I was going to live this long I would have taken better care of myself "
Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER....
Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen ,
Bill72BB is offline   Reply With Quote
Old 08-18-2002, 07:22 PM   #3
junkyardjohn
junkyardjohn's Avatar
Thumbs up
71 -- ARE YOU TALKING ABOUT THE ANTI-RATTLE FUZZIES OR THE WINDOW CHANNEL?? THEY'RE BOTH PRETTY EASY TO INSTALL. BEFORE YOU TRIM ANY OFF THE FUZZIES, MAKE SURE THE TABS LINE UP WITH THE HOLES THAT THEY GO INTO,& B-4 YOU CLIP ANY IN ALL THE WAY. HAVE THEM ALL STARTED IN THE HOLES. THE CHANNEL IS PRETTY EASY TOO. I FOUND THAT IT HELPS TO FEED IT IN PAST THE GLASS AS FAR AS YOU CAN GET IT DOWN, THEN ROLE THE WINDOW UP ABOUT HALFWAY, & AS YOU ROLE THE WINDOW DOWN, FEED THE CHANNEL DOWN WITH IT. CLEAR AS MUD HUH?? IT'S NOT THAT TOUGH JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 08-21-2002, 09:56 PM   #4
chewed 71'er
Thanks for info, gentlemen. Wanna get moving on this before weather starts cooling down.
