Has anyone done a newer pedal style E-brake conversion? If so how hard was it and what year did it come off of?
Re: Pedal Style E-brake?
i would like to know too, i was thinking about doing the same thing to my 67 LWB
The foot pedal brake started in 69. They really don't fit in a 67/68. You have to modify the firewall to use it in the early truck or modify the E-brake pedal assembly.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
I haven't done it in a truck but there are quite a few GM cars that have a small style e-brake. Check out some junk yards and look for FWD cars
I went from a pedal style e-brake, on a 71 cab to a lever type e brake. I wanted a org 68 looking cab . Just cut the top left corner of the fire wall out, and put a 69 or later section in its place. A little work,but can be done.
98 Chevy Z71 1500 extended cab 99 Dodge carvan es 68 Chevy C10 LWB 50TH 396 eng 400 Trans 62 Wheel Horse tractor in good shape |
Thanks for the info. It might be my next improvement.
http://www.classicperform.com/Store/...es/EFB9000.htm
They have a billet assembly that looks pretty good. It isn't cheap however. |
#8 | |
Licensed to Thrill!
I have considered doing that to my '71 just so I could change the position of my pedal style e-brake (and I want the midnight series pedals from Lokar ![]() If you could get it positioned right - kick panel speakers would be a snap. ![]() Welcome to the board nic. |
