Old 11-27-2006, 08:02 PM   #1
chevyc1068
chevyc1068's Avatar
Worn out springs?
How can you tell when coil springs are worn out? Do you think if they are 38 years old that they are worn out? Because I have to decide whether or not to replace them or not.
1968 C-10 longbed, 307 V8, 4spd- currently under construction
chevyc1068 is offline   Reply With Quote
Old 11-27-2006, 08:06 PM   #2
st1x10
st1x10's Avatar
Re: Worn out springs?
38 years old, they are probably worn out. Also some trucks came with the inline 6's had different springs and swapping a sb would make it sit lower. I think LMC has some measurements and I believe it should be 2" lower in the front. I believe 34 front 36 rear. Somebody correct me if I am wrong.
1970 Chevy C10 "Under Construction"
2002 Chevy S10 V6
st1x10 is offline   Reply With Quote
Old 11-27-2006, 11:42 PM   #3
chevyc1068
chevyc1068's Avatar
Will coil over shocks really compensate for worn out springs? If so where are some good places to get coil over shocks?
Old 11-28-2006, 11:17 AM   #4
Tony@AirRideTech
Junior Member
If your springs are tired and old they need to be replaced....
Tony@AirRideTech is offline   Reply With Quote
