Old 11-28-2006, 12:53 AM   #1
bad_turbo
turbo enthusiast
bad_turbo's Avatar
rearend question
looking at acquiring a 1 ton rearend out of an '81 truck for my '69 1 ton flatbed. I have a choice of a rearend from a regular '81 flatbed 2wd truck or the rearend out of an '81 1 ton 4x4 truck. Both are stock but is one harder to make fit than the other? Are the lengths different? Thanks
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 11-28-2006, 01:03 AM   #2
brak
brak's Avatar
Re: rearend question
I would think that externally they would be the same, and the differences would lie internally, such as gearing, Posi, etc...
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 11-28-2006, 01:16 AM   #3
kwmech
Take a tape measure with you, one or the other axles will have different spring width, than the 69. I think you want 40 1/4'' .
Old 11-28-2006, 01:37 AM   #4
skchevota
skchevota's Avatar
from those years they should both be 14 bolt fullfloats with 10 1/2 ring gear. the widths should be the same if they are both single rear wheel. If they are a dulley than it will be 6" wider. like stated above gear ratio and posi ect,. could vary. and the spring pad width could very but if they are both 1 tons they should be the same. I would pick which ever one is in the best condition and has the gear ratio you want. You can always relocate the spring pads.
skchevota is offline   Reply With Quote
Old 11-28-2006, 01:41 AM   #5
Boise69
The Hammer Man
Boise69's Avatar
:bansex: ?? oh, my bad, i thought i knew the answer
Boise69. Bought in Boise ID and its a '69
___________________________________________
1969 Chevy C-10 SWB 350/400 - drivable project
www.americanhammer.com
2013 MBZ Sprinter customized
2005 MBZ Sprinter Van
2004 Land Rover Discovery
2001 Yamaha Road Star
1997 MBZ E420
1989 Ferrari Mondial T
Boise69 is offline   Reply With Quote
Old 11-28-2006, 01:45 AM   #6
bad_turbo
turbo enthusiast
bad_turbo's Avatar
the 2wd is a dually the 4x4 is a single rear tire
