Old 11-28-2006, 04:40 AM   #1
turbochevy
GEN III Chevy Small Block Install
Has anyone completed this swap? I see Brothers has the motor mounts available. I am wondering if there is another member that has done this swap with sucess and if there are pics available of the work completed.
Thanks in advance.
1970 Chevy C 10 SWB
turbochevy is offline   Reply With Quote
Old 11-28-2006, 08:42 AM   #2
Misstur_big
Junior Member
Misstur_big's Avatar
Re: GEN III Chevy Small Block Install
What ever you need to know I'll try to help you with.
Mine is a Gen 3 with a 4L60E and a 3.73 posi 1967
Misstur_big is offline   Reply With Quote
Old 11-28-2006, 10:52 AM   #3
turbochevy
My biggest questions right now are motor mounts, I asked the same question in another thread. I am looking very hard at the Brothers set up, it looks well done and complete. This is the only area where I just do not have the time or patience to deal with figuring out what, where, and how.....everything else is pretty straight forward.
1970 Chevy C 10 SWB
Old 11-28-2006, 02:26 PM   #4
Misstur_big
Junior Member
The only problem I had with the mounts was using the small block towers. It wouldent have hurt for the engine to be set back another 2 inches. I amnot sure how to deal with this unless you had them custom made. Of course then you have the issue of the oil pan hiting the cross member so there may be no way around this. My mounts came from Street and strip and they are basically adapter plates that bolt on the block and allow you to use stock mounts and towers. My engine came out of a 4x4 and the pan sump just fit in front of the crossmember. Does your engine have the sump in the rear? If so, I think you would be better off setting the engine back a bit. Since mine is not an LT I am going to differ this question to someone who has installed a LT or LS
Old 11-28-2006, 02:43 PM   #5
turbochevy
mine came out of a Hummer H2, it has the pick up in the rear of the motor. I am planning to move the motor back as far as I can for clearance later for the turbo intercooler.
1970 Chevy C 10 SWB
Old 11-28-2006, 03:22 PM   #6
ChevyFan24
Junior Member
I purchased the Early Classic Enterpises GEN III motor mounts. They just arrived yesterday. I will install tonight and post a picture later if you would like.
ChevyFan24 is offline   Reply With Quote
Old 11-28-2006, 04:16 PM   #7
turbochevy
PERFECT!! Thanks!
1970 Chevy C 10 SWB
Old 11-28-2006, 05:25 PM   #8
billyjo
Junior Member
billyjo's Avatar
I know that the ECE mounts won't work on a 4wd Blazer.
1972 K/5 4x4, Radixed LS1 6.0, 428HP/445TQ, Lingenfelter GT2-3 cam, WCCH 90mm J-Tube, LS2 90mm TB, Stainless Works Headers, NV4500, 4.56 gears, Detroit Lockers, 14 bolt FF, Dana 60, 4 wheel disk Hydro Brakes, dual electric fans, Autometer guages, 4" lift, Zero Rates, Weld Evo Velocity XT8 wheels, 35x12.5x17 Super Swamper SSR's.....
http://s72.photobucket.com/albums/i1...tos/?start=all
billyjo is offline   Reply With Quote
Old 11-28-2006, 05:54 PM   #9
turbochevy
Hey billjo, BlownChevy from performancetrucks.net!
1970 Chevy C 10 SWB
Old 11-28-2006, 06:02 PM   #10
billyjo
Junior Member
billyjo's Avatar
I wondered but when I saw the "turbo" I figured no way. If you decide you want to use the ECE mounts I have a set that maybe we can trade something for if your interested.
Old 11-28-2006, 06:03 PM   #11
turbochevy
I think they will work, what do ya need??
1970 Chevy C 10 SWB
Old 11-28-2006, 06:45 PM   #12
billyjo
Junior Member
billyjo's Avatar
PM sent
Old 11-28-2006, 11:25 PM   #13
ChevyFan24
Junior Member
Here are pics of the ECE Gen II motor mounts. I just have them in place with old bolts to mark the bottom holes to drill. The top holes line up but it appears that I do have to drill the lower ones. Nice clearance on the left side but I will need to notch the top of the right frame around the a/c lines with the factory a/c compressor on the 5.3. The fan sits equal with the front frame crossmember. Hope these help.
Old 11-28-2006, 11:28 PM   #14
ChevyFan24
Junior Member
And the engine location.
Old 11-29-2006, 12:27 AM   #15
turbochevy
nice, gives me an idea of what I am up against. Do you have a pic of the AC pump and the lines?
1970 Chevy C 10 SWB
Old 11-29-2006, 09:53 AM   #16
shifty
Questionable
shifty's Avatar
I have done the swap and I am using the ECE mounts also.
Click the link to the ls1tech thread in my signature for a 9-page long thread (and growing) with tons of picks. Click on the link of the make/model of my truck for an assload of pictures. I'm almost ready to fire up.
It is possible to fit A/C compressor/clutch in, but it is a damned tight fit. I just deleted mine, I'll worry about it later.
I can answer questions and give advice, but ... I don't post here that often anymore, so ... My recommendation to you is to go sign up and watch the Conversions/Hybrids forum at LS1tech, because you'll get a lot more help there than over here.
Be sure to familiarize yourself with the Search feature at this site, search for GenIII and you'll get a lot of pages. Look on the first page of my LS1tech thread in my signature for a link to other swaps and galleries covering this swap.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 11-29-2006, 12:02 PM   #17
turbochevy
I have been checkin it, thanks for the reply. Been a member of tech since 2003
1970 Chevy C 10 SWB
Old 11-29-2006, 02:12 PM   #18
shifty
Questionable
shifty's Avatar
nice
Saw your post over there
Old 11-29-2006, 02:15 PM   #19
turbochevy
nice
Been lookin at your thread, so far this looks pretty straight forward.
1970 Chevy C 10 SWB
Old 11-29-2006, 04:23 PM   #20
shifty
Questionable
shifty's Avatar
I literally think our trucks probably have one of the absolute most straight-forward plug-and-play installations for this swap. Seriously.
If there is an easier car out there to swap a GenIII motor into (that doesn't already come with one optional), I would like to hear it.
The only thing I know that has the aftermarket support for it is the Porsche conversion kits that Renegade Hybrids sells to make it totally plug-and-play, but it costs a hell of a lot more.
Old 11-29-2006, 05:53 PM   #21
turbochevy
Good to know! Thanks.
1970 Chevy C 10 SWB
