Like a Rock!
Which Flowmaster mufflers you runnin'?
What size/configuration flowmasters are you using with full length headers?. I want to see flowmaster pics with full length headers if you got em'. Mine hang down TOO FAR under the truck and look crappy
69 LWB Runs great - work in progress Mess with me and you mess with the whole trailer park! ![]() |
![]() Join Date: Jul 2006
Re: Which Flowmaster mufflers you runnin'?
I am running the 3 chamber 50 series delta flows. I did have the original 40's and they are way loud. I figured I'd spare my neighbors and went with the slightly quieter ones.
If you want to hear them click this link. http://youtube.com/watch?v=XQjN072mJWU Good luck, B-dub |
Forgot to mention that I'm running Hedman Elite mid length 1 5/8" primary headers.
I did have long tube 1 5/8" before. I think at some point I'm going to 1 3/4" equal length long tube headers. |
I have a FI 454 that breaths through two 3" Flowmaster 50's
Project Family Values Build Thread Vehicles/Projects: -1971 C10 SWB Fleetside! Gathering parts now, will begin frame-off resto soon... Pleasure in the job puts perfection in the work. -Aristotle |
sufficiently talented fool
![]() Join Date: Jun 2006
I am usingflow tech headers with 2 1/2 inch pipe and 2 chamber Flowmasters with 3 1/2 stainless tips. My exhaust is below the frame from the headers to the trailing arm crossmember, then goes up to the mufflers.
"it's impossible to be surrounded by idiots when you are part of the circle" ![]() 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board |
NOT REALLY BANNED!
![]() Join Date: Jul 2004
2 1 chamber 3" mufflers.
Less interior drone than the 2-3 chambers, sounds like a 5.0 mustang, but only on a chevy.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily. 04 Pontiac GTO 04 Ford Mustang GT 68 C20 LWB stripper truck 73 K5 Cheyenne 76 C20 Sierra Crew SRW 88 K20 Suburban I'm not hammering on metal just to hammer, i'm creating a piece of art. |
Gone Fishing
I'm runnin some cheap flotech headers and 2.5 pipe all the way dumped in front of the rear with my 40 seriers flows
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop ![]() 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
I am running hedman long tubes with 2 40's series
i dont like for my exhaust to sound like its going thru a garbage can so i dont use blowmaster mufflers
I survived Dead Man's Curve.
I think Flowmasters have their own cool, unique sound, but for some reason I consider it cheating. Don't ask why. I just believe in cherry bombs for an old street rod pickup. Call me old-fashioned, all the import guys do.
"The people should not be afraid of their government. The government should be afraid of it's people." "The Hurricane" 1967 Chevrolet C10 350 Eight Cylinder, 700R4 BowtieOverdrive Cherry Bomb... Disturbing the Peace Since 1968. ![]() |
village idiot
Gibson headers,3" single from front to back with a 50 series Flomaster on my Ram 1500 is damn near as loud as any 40 series I've ever had
i'm a big fan of the super 40's.
i had a 3" in dual 2.5" out on my 89 gmc with a 350 sounded amazing. i also have 2 2.5" on my 2001 mustang gt which is quiet but the tone is perfect |
#13 |
Sounds like your exhaust sytem was not installed very well, or without attention to detail. It should be possible to have everything mounted up high and tight, even with Flows if that is what you like. On both of my trucks the exhaust is barely visible from the side until it exits out the back. Sorry no pictures. ![]() |
#14 |
2 1/2 w/ super 40's (i think, bought them used) i have holes in my crossmember so everything is up tight and can not be seen from the side. the guy before me cut notches out of the crossmembers for the prev. exhaust so my exhaust guy used that to his advantage. my flows are sitting sideways beside the driveshaft I O I <--- like that and it works out perfect. i wouldnt mind a bit more sound but it sounds nice at idle w/ NO DRONE/RESONANCE at cruiseing speeds.
#15 |
454 with Hooker Competition headers and dual 3'' Flowmaster 40 series with turndowns just ahead of the axle. Loud enough to set off car alarms, scare small children and animals, and ehco like hell in the cab.
'70 GMC SWB step-side- 454, 4 speed, air bags (in progress) '09 CTS-V M6 '03 Sierra SWB Z71 '82 Yamaha Seca XJ650R Turbo! '04 Yamaha FZ6 |
#16 |
Fabricate till you "puke"
Hooker comps,2 1/2" pipe/H pipe, 50's flows set approx 1 ft behind the cab, with rear exit tail pipes(also 2 1/2"). It is fairly quiet, with little interior noise......till you stand on the loud peddle
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... Last edited by crazy longhorn; 11-29-2006 at 11:34 AM. Reason: spelling |
#17 | |
I had my exhast run inside the frame rails and underneath the drive shaft loop and over the trailing arms. I really wanted to either buy the loop with the holes cut in it for exhaust or make my own.....However, the place that did the work, Muffin Muffler in Austin Texas, did a FANTASTIC job and you can't see the pipes. The put them as far up as possible. |
#18 |
Let's try that again.
#19 |
Keepin an eye out
I have the 40's...loud.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
#20 |
I have the stock L6
FOR SALE 69 c10 LWB...best offer |
#21 |
Like a Rock!
Does anybody here have "full length" headers with a clean tucked up exhaust???. It looks like only ram horns, shorties and mid lengths will give the hidden look
69 LWB Runs great - work in progress Mess with me and you mess with the whole trailer park! ![]() Last edited by c10crazy; 11-29-2006 at 01:24 PM. |
#22 | |
Good luck. B.T.W. I'd love to hear if anyone knows of a full length that doesn't had down. |
#23 |
![]() Join Date: Oct 2005
I have an old set of 3 chamber Flow Masters on mine that I've had for probably 10+ years.
Haven't they changed somewhat with the "series" identifiers and "Delta" etc.... Do the newer muffs sound different then the older 3 chambers?
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread |
#24 | |
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
