Old 11-28-2006, 09:46 PM   #1
BigShoe24
True Addiction
BigShoe24's Avatar
Rear Set-up
Ok guys, I have been thinking about this for awhile and cant make my mind up. As of now, I have installed my kpcomponent step-notch. I have a 68 swb and already have the front bagged. Im wondering what is the most practical way to set-up the rear. Should I keep the stock setup, two long trailing arms? Should I replace them with some aftermarket ones? Or should I go with a
4-link? This is my first truck, so I dont want to get crazy, but I want to do it right. Any pictures of rear suspension's would help tremendously! Thanks
BigShoe24 is offline   Reply With Quote
Old 11-28-2006, 10:02 PM   #2
jimmydean
jimmydean's Avatar
Re: Rear Set-up
The easiest would be to keep the stock trailing arms if they are in good shape and just add bags to the rear. If the arms are rusted or starting to come apart, then tubular arms would be a nice option.
If you want to get low, then a 4 link would be nice.
jimmydean is offline   Reply With Quote
Old 11-28-2006, 11:45 PM   #3
leftcoast66
leftcoast66's Avatar
Re: Rear Set-up
ya, sounds like ur not plannin to lay on the ground by any means, so I'd go for just bags ontop of your trailing arms, or a 4 link of the trailing arms are fallin apart.
leftcoast66 is offline   Reply With Quote
Old 11-29-2006, 01:51 PM   #4
project76
project76's Avatar
Re: Rear Set-up
I agree bags and blocks for the stock trailing arms will get you really low.
Brandon
project 67 swb bagged on 20" Coddingtons
project76 is offline   Reply With Quote
Old 11-29-2006, 03:30 PM   #5
leftcoast66
Re: Rear Set-up
With only a stepnotch I don't think he'd have room to go any higher with blocks. The axle tucks up high to begin with and would probably only be able to use 1 inch block at most IMO.
Old 11-29-2006, 04:09 PM   #6
BigShoe24
True Addiction
BigShoe24's Avatar
Re: Rear Set-up
Its a 7" notch, Also, what kinda of money would it be to rebuild my rearend? Im pretty sure everthing is shot, also need to swith from 6 to 5 lug. Does anyone have a few pics? I need some visual please!
Old 11-29-2006, 04:15 PM   #7
jimmydean
jimmydean's Avatar
Re: Rear Set-up
When I called around about a rebuild, it was about $800, but that included a rebuild of the posi unit. I ended up changing the oil and adding the friction modifier, cleared the "clunk" I had right up.
They now offer a 5 lug axel that you can swap out if you're having the rear done anyway.
Old 11-29-2006, 04:19 PM   #8
BigShoe24
True Addiction
BigShoe24's Avatar
Re: Rear Set-up
Sorry, Im attempting to upload some pics
Old 11-29-2006, 04:48 PM   #9
project76
project76's Avatar
Re: Rear Set-up
Looks great!! With the drop spindles on there and a decent size tire you will be laying that crossmember on the ground. I had the same kp notch out back and with bags and blocks you will be laying it lower than the front. Are you looking to go disk or stay drum when you go to 5 lug out back?
Brandon
Old 11-29-2006, 09:03 PM   #10
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Re: Rear Set-up
Where do you have your bags mounted out back? With the KP step notch where do they mount up top? Still in the factory spring location? Reason I ask is because I just have the CPP bolt-in c-notch and have Slam RE7 bags and they are on the internal bumpstops when I air it out and the axle is just touching the top of the notch without the snubber in it. I don't see how I'd get any lower with the bags in the factory location so it would be pointless to do a stepnotch unless I mount the bags elsewhere. Do you have any pics of your setup?
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 11-29-2006, 11:13 PM   #11
leftcoast66
Re: Rear Set-up
I stand corrected, 7" notch u'll want either tubular trailing arms or somehtin like that to get it lower or blocks like bigshoe suggested.
Old 11-29-2006, 11:33 PM   #12
project76
project76's Avatar
Re: Rear Set-up
I ditched the setup last month and im building a full backhalf with a kp 4 link as we speak. I am buying a dropmember from porterbuilt in a few months so i need to get the rear a few inches lower. When i had the step notch i made a bridge between the notch's and mounted my bags on the front of the axle with a kit from suicidedoors. I dont have any pics but its just your basic bridge kit with bags mounted in front of the axle not over it like some do. If you want to keep the bags in the stock location and get very low, you are gonna have to build your own notch and bring it all the way up past where the trailing arms cross under the frame. How low do you wanna go? Keep in mind that your not gonna get much lower without going into the bed floor.
Brandon
Old 11-30-2006, 12:46 AM   #13
BigShoe24
True Addiction
BigShoe24's Avatar
Re: Rear Set-up
As of know, Im planning on staying with the stock trailing arms, perhaps replacing them with tubular bars. With the Kp notch, slam bags, and will probably place the bags in front of the rear-end. The guy that owns use to have a black truck posted on this site with the exact set-up. If anyone can find it, I would appreciate it. Keep comming with the input though, every idea help!
Old 11-30-2006, 02:07 PM   #14
el curioso
el curioso's Avatar
Re: Rear Set-up
I know that im going to get chewed out on this but here it goes
If your willing to stay with your trailing arm set up and have some fab skills why not build a 2 link set up running along the uot side of your frame and have the pinion angle at ride hight. Thene later if you whant to four link the bars can easily be modified for a 4 link set up.
JMO.
1969 Chevy C-10 350/700r4
el curioso is offline   Reply With Quote
Old 11-30-2006, 07:03 PM   #15
67Fleet
67Fleet's Avatar
Re: Rear Set-up
JMO.
because 2-links ride like dog-s*$@. I'd rather have air-over-leaf than a 2-link, and that's not saying much..... Every truck I've ridden in with a 2-link was awful. Driveline vibration, wheel hop, and rough ride. The driveline vibration can be fixed if you always want to keep it at a fixed ride height, but the other issues don't go away.
-Bret
