![]() Join Date: Mar 2003
I'm adding a tach to my truck and need a picture of the firewall(origional location) that shows where the tach wire comes out of the firewall to the hei,so I know where to drill the 3/4" hole on the firewall? Thank you
Re: picture please-tach wire on firewall?
There is a series of dimples between the bulkhead connector and the E-brake cable hole as can be seen in the picture, (attached). The hole for the tach should be made using the dimple that is centered between the two larger holes.
Jim |
thank you very much for the picture.
