Old 11-29-2006, 11:36 AM   #1
GBWatts
GBWatts's Avatar
Question Installing a new rubber grommet
I need to install a new 2" rubber fuel neck grommet on my 67 stepside. Is there any easy way to get this done short of pulling the fuel tank?
GBWatts is offline   Reply With Quote
Old 11-29-2006, 11:41 AM   #2
cdowns
cdowns's Avatar
Re: Installing a new rubber grommet
heat it up in boiling water and use liquid dishsoap to lubricate it
Old 11-29-2006, 01:42 PM   #3
Old 11-30-2006, 09:33 AM   #4
grayw0lf
A little lithium grease helps too.
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 11-30-2006, 02:17 PM   #5
farmerfred
Sylglide is made for lubricating rubber. It doesn't dry out as quickly as dish soap, in my experience. I haven't replaced the fuel neck grommet, but it's been good stuff in other installs.
1972 C-20 350
farmerfred is offline   Reply With Quote
Old 11-30-2006, 02:44 PM   #6
BobRitts
I used a hard plastic scraper to help push the lip into the hole in the body, wood would probably work too. Plastic won't scratch the paint if (i.e., WHEN) you go OOPS and slip a bit and hit the paint!
BobRitts is offline   Reply With Quote
Old 11-30-2006, 03:43 PM   #7
GBWatts
GBWatts's Avatar
Thanks All. The boiling water, soap and a plastic putty knife did the trick.
Now on to the next problem putting my truck back together faces me with!
GBWatts
