Old 11-29-2006, 12:28 PM   #1
abadsvt
abadsvt's Avatar
Temporary air gauge and switch. Where to find?
I am in the need of a temporary psi gauge and switch. I want to check my work and make sure everything is working how it should. Where can i get a guage? What about cheap switchs? thanks Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 11-29-2006, 02:17 PM   #2
jimmydean
jimmydean's Avatar
Re: Temporary air gauge and switch. Where to find?
I bought my gauges off ebay for $6 each (dual needle 150psi). I was going to run the gauges Porterbuilt posted a while back because they are small and he said that was all he used. They were also somewhat cheap, like $20 or something and 1 5/8" in size if I recall.
You can get a switch at Autozone for like $4.
Got any progress pics? It's looking good so far.
jimmydean is offline   Reply With Quote
Old 11-29-2006, 05:16 PM   #3
abadsvt
abadsvt's Avatar
Thanks Jimmy! I was looking at one on ebay but wasn't sure if you can buy some at a local automotive shop like kragens or autozone. $4 for a switch is perfect. I just want something so i can test it at ride height to make sure i got the correct angles and what not since i am doing a cantilever setup for the rear suspension. Hopefully i will have some more done by this weekend and i will post some pics for sure. Thanks again!
Josh
(Project truck)
Old 11-29-2006, 06:10 PM   #4
jimmydean
jimmydean's Avatar
Any momentary SPDT (single pole, double throw) switch will work. Just make sure it's momentary (as in it returns to center when released). Good luck with that, I can't wait to see it.
