Old 11-29-2006, 01:00 PM   #1
bryanw1968
bryanw1968's Avatar
New heads, intake and rockers pic.....
O.K., so you can't see the rockers
bryanw1968 is offline   Reply With Quote
Old 11-29-2006, 01:39 PM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: New heads, intake and rockers pic.....
Looks great - what are the specs?
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 11-29-2006, 02:34 PM   #3
70c10
67-72 Addict!
70c10's Avatar
Looks great! Where did you get those blue heater hose clamps?
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 11-29-2006, 02:35 PM   #4
bryanw1968
bryanw1968's Avatar
350 .030 over '73 4 bolt vette block
comp extreme engergy 268 cam
trick flow Kenny Duttweiler series aluminum 195cc heads w/1.46 springs and 7/16" studs 2.02/1.60 valves
comp pro magnum stainless steel 1.6 roller rockers
edelbrock rpm intake
hedman elite 1 5/8" hedders
barry grant speed demon 650 mechanical secondary
MSD pro billet dist, blaster II coil, 6AL box
On paper I should be making around 430HP at the crank.
"should"
Old 11-29-2006, 02:36 PM   #5
bryanw1968
bryanw1968's Avatar
I got them at Austin Performance here in town but I'm pretty sure Jegs and Summit have them. I think they're made by Earls.
