Old 11-29-2006, 05:15 PM   #1
Angelse68cal
Cochino_Racing_909
Angelse68cal's Avatar
On HEI for 350
DOes anyone know where the #1 is and which way the firing order rotates on the distributor?
Angelse68cal is offline   Reply With Quote
Old 11-29-2006, 05:27 PM   #2
krue
Designated A-hole!
krue's Avatar
Re: On HEI for 350
Rotates clockwise. I know there is a "factory" position for #1 but I don't remember what it is. I usually stab the dizzy and find tdc on #1 and start wherever the rotor is pointing.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 11-29-2006, 05:39 PM   #3
Angelse68cal
Cochino_Racing_909
Re: On HEI for 350
BUt would you happen to know where #1 is on the dist.
Old 11-29-2006, 05:40 PM   #4
krue
Designated A-hole!
krue's Avatar
Re: On HEI for 350
No, sorry. Let me look around, I know it's been posted before.
www.daveramsey.com
Old 11-29-2006, 05:41 PM   #5
krue
Designated A-hole!
krue's Avatar
Re: On HEI for 350
http://67-72chevytrucks.com/vboard/s...t=firing+order
Here you go.
www.daveramsey.com
Old 11-30-2006, 04:03 PM   #6
70rs/ss
70rs/ss's Avatar
Re: On HEI for 350
I usually put it next to the where the wiring goes into the cap (to the right of the square part of the cap). But anywhere the rotor points at top dead center is #1!!!! I usually pull the #1 plug and rotate the motor untill the compression blows the finger out (the timing mark will line up with the tab as well) then put the rotor pointing at the #1 plug and set the wires accordingly (clockwise) set the dist housing with enough room to advance and retard the timing without hitting anything as well!!
70rs/ss is offline   Reply With Quote
