Old 11-29-2006, 09:04 PM   #1
Rebeltilldeath3
Vacum nipple/port
Well today I found a massive vacum leak. I had been suspecting the EGR or TPS for the cause to be running lean, but I found the vacum leak to be the cause.
The vacum nipple is on the intake manifold, offset slightly to the passenger side I believe. It's next to the EGR and in front of the distributor. It's a fairly large nipple. It took a rubber fuel line to slip over it to block it off for now.
What SHOULD be hooked up to this vacum nipple? I can't find any loose vacum lines.
Rebeltilldeath3 is offline   Reply With Quote
Old 11-29-2006, 09:42 PM   #2
beaterC10
Re: Vacum nipple/port
Normally you will have vacuum to the brake booster, A/C doors, trans vac modulator, etc. That nipple is the source for anything that requires manifold vacuum.
beaterC10 is offline   Reply With Quote
Old 11-29-2006, 11:39 PM   #3
Rebeltilldeath3
I know that, but usually each individual source of vacum has a designated item that hooks to it.
Old 11-30-2006, 08:38 AM   #4
beaterC10
On the trucks I have owned, the items I mentioned were connected to the nipple you are talking about.
