Old 11-30-2006, 12:21 AM   #1
bodyman9174
Hello all
Well it lookslike I'm goingto be getting a 71 c10. What are something i should looking for to be worn out or should replace to make sure this truck is reliable.Right now they drive it ever now and than. The only thing that i know that is rust it out is the drive side body mount on the cab. were would be a good place to get this? And theres a rust hole in the cap coner. About the size of a 1/4. thanks for the help all
bodyman9174 is offline   Reply With Quote
Old 11-30-2006, 12:36 AM   #2
Aarons72s
Re: Hello all
Welcome back and congrats on your acqisition. Try any of the board members for your parts. Such as brothers and gmc pauls. They will have what your looking for. Its pretty much go over it with a fine tooth comb. Check the brakes and suspension carefully. To make sure everything is in working order. How well did they maintain it? will help in what you need to do. Like I said look it over and if you see something that concerns you ask us for advice. Get pictures for us and we will look it over and tell you anything that may be a problem. Again welcome back. We will try are best to help you out.
Aarons72s is offline   Reply With Quote
Old 11-30-2006, 01:04 AM   #3
bodyman9174
Re: Hello all
Thanks man man pretty much not familar with the sup set up the the back.. Evrything else i can check out. Going to do a tune up,belts,hoses,ect ect.. Just don't really know what prts in the back wear out.
Old 11-30-2006, 12:47 PM   #4
raggedjim
raggedjim's Avatar
Re: Hello all
The mechanicals on these trucks are a breeze. I'm assuming it has the trailing arm with coil springs rear suspension (since almost everyone has seen leaf springs). It's a good riding setup. Check the trailing arms for rust between the 2 pieces. I've seen them rust in two.
The most $$$ you will spend is fixing rust so get one with as little as possible (advise I wish I had taken...)
Good luck, Rg
Good luck
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
