Old 11-30-2006, 03:32 AM   #1
lilpup69chevy
67-72 parts finder
lilpup69chevy's Avatar
engine runs fine for a few minutes then stalls
i am curious to anyone who has had a problem like i'm having on my 68 chevy i just bought with a 250 I6 3 spd truck, anywho on the way home it ran fine till i got about halfway home with it then it started cutting out and acting like it was out of gas but it had half a tank, well left it went to the shop to get some tools took off the fuel filter started up ran a little rough at first then it ran fine the rest of the way then died in my yard, well the things i've done its not a carb problem as the choke is not sticking, no vaccum leaks at carb, tried another carb that i know is fine still does it, it really acts like it is starving for fuel, but there is fuel coming out of the line when you crank it, is it possible for it to get weak as it warms up or is it just an ignition problem perhaps? it has me baffled at the moment because i've checked most of the basic stuff any tips or ideas are appreciated thanks
1969 chevy shortstep 2wd (under construction)
1981 chevy scottsdale lwb 2wd (parts chaser)
2004 pontiac gto (daily driver)
2004 pontiac grand prix gt (the ol ladys car)
1985 chevy short wide
1970 chevy c10 lwb (another parts rig)
1969 gmc lwb (rainy day project)
1968 chevy lwb c10 250 I6 3 spd (soon to be swb)
lilpup69chevy is offline   Reply With Quote
Old 11-30-2006, 06:38 AM   #2
Re: engine runs fine for a few minutes then stalls
Sounds like some junk got in the fuel lines or carb. Since you switched carbs, I 'd say it eliminates the carb being clogging up as the issue. You could have some trash in the tank that might be clogging up the pickup sock. The other possibility is your fuel pump might be going.
Old 11-30-2006, 07:52 AM   #3
Misstur_big
Junior Member
Misstur_big's Avatar
did you check fuel pump pressure?
If its no the pump my et would be trash in the fuel tank pluging up the pickup screen.
Misstur_big is offline   Reply With Quote
Old 11-30-2006, 12:20 PM   #4
cduster
fuel tank vent plugged? try loosening the gas cap and see if that helps. Just a thought.
Good Judgment comes from experience.
Most experience comes from bad judgment.
cduster is offline   Reply With Quote
Old 11-30-2006, 05:02 PM   #5
Jayman931
Jayman931's Avatar
fuel pressure issue...i agree
Jayman931 is offline   Reply With Quote
Old 11-30-2006, 05:12 PM   #6
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
You may also want to check the points and condenser,.I've seen them show an open when warm.Or if it has been upgraded to an HEI it could be the module.I would think the fuel problem more likely but if that's not it.....
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 11-30-2006, 07:10 PM   #7
lilpup69chevy
67-72 parts finder
ok guys thanks for the tip, i was thinkin it sure seems like its an issue of lack of fuel, gonna try a different pump and look and see what the tank and lines look like i have a few other trucks that may have what i need, if its the points then i have an hei setup for it and i'll just switch it over thanks for your help guys
Old 11-30-2006, 08:50 PM   #8
Boog
laying low
Boog's Avatar
If you do switch it over to HEI be sure it has a full 12 volts going to it. The points dist uses about 9 on a resistor wire.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 11-30-2006, 08:58 PM   #9
truckdude239
truckdude239's Avatar
my truck would cut off at an idel turned out the points where gone
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 11-30-2006, 09:41 PM   #10
Boog
laying low
Boog's Avatar
If you've got fuel and spark it's supposed to run. Turning the engine over pumps fuel out the line so that takes care of that. Do you have spark to the plugs when turning it over? What about the exhaust? Free flowing or old crusty original? Sometimes an old exhaust pipe can colapse inside restricting the flow and shut one down.
First thing to check is whether it still has spark to the plugs and fuel in the carb just after it shuts down.
Boog
primer is finer
Old 11-30-2006, 10:44 PM   #11
lilpup69chevy
67-72 parts finder
yes it has both of those after it shuts down, the thing with the exhaust is it is just a straight pipe so no restriction, i'm thinkin its a weak fuel pump or the points now, because i keep checking the fuel filter in the carb and its not getting any trash in it nor is it stopping up my inline filter so guess gonna put another fuel pump on it after i check the points, is it possible for the coil to act something like that???
Old 11-30-2006, 11:15 PM   #12
Boog
laying low
Boog's Avatar
Well, usually a coil dies pretty quick. That's not to say that's not your problem but my experience with bad coils has been when driving along it loses power and misfires a bunch 'till it finally quits and will not restart. I would do a tuneup on it with points, condensor, rotor, cap and plugs, maybe wires too. Then if you get a good blue spark at the plugs you have a good coil and this should eliminate the ignition system as the source of the problem. Oh and the points dist runs on about 9 volts. The power wire to the dist is most likely a resistor wire. If someone has run 12 volts to the dist the points won't last long. The HEI dist does need a full 12 volts. You'll need to check this. HTH
About the fuel: when the engine shuts down reach out there and loosen the gas cap and see if there is a whoooosh sound. If so then the tank is not venting and actually under a vacumn and after a while the pump cannot pull enough gas out of it. If I'm not mistaken the early ones used a vented gas cap for this reason. Like trying to pour gas from a can without the vent hole open, see.
Boog
primer is finer
Old 12-02-2006, 08:59 PM   #13
lilpup69chevy
67-72 parts finder
well good news guys i got it running and all the asumptions i checked at first were wrong, but when i went to check the points that was not the problem the distributor shaft was wore out, i guess the bushing itself? i know it had about a 1/2 inch of play in it so i grabbed another dist out of another truck and changed it and put in new points and condensor put on the stock carb and it runs like a top. by the way i did check everything else and i appreciate all the tips because i'm sure since this truck sat awhile it needed to be checked but i hope me telling exactly what the problem was helps someone else in the future thanks again guys
Old 12-03-2006, 08:58 AM   #14
68C15
blood type; Retumbo
68C15's Avatar
I would still swap over to HEI. its just a matter of time till the other dizzy gives out. to this day have yet to see a reman dizzy with new shaft. worn points cam = short dwell time=weak spark.
68C15 is offline   Reply With Quote
