Thanks everyone for your help on getting a fuel neck rubber grommet installed. Boiling water, dish soap and a little push or two from a plastic putty knife did the trick.
So now the next item I am hjaving a problem with. My painter reassembled the front fenders on the truck before he re-installed the Bowtie / 10 emblems which of course bolt on. Any ideas on how to install them without having to pull the fender? I thought about using the 4 holes as guides to drill a pilot hole into the air vent box from the outside and then using a 5/8" drill on the inside to make a hole large enough to fit a 3/8" socket thru and then covering the holes with nylon caps, but I really don't know if I want to have 4 holes in each vent box. |
Re: Emblem Installation
You can bolt them on with the fenders on. I got them off of my 72 without pulling the fender or inner fender. Get you one of those ratchet wrenches, put the emblems on and stick your hand up in there and put the nut on. And wrench them on. It is a pain to get your hands up there but it can be done.
Hope this helps. |
That idea might work for the bottom 2 bolts but there is just no way to get a hand or a wrench up on the top 2, the air vent box (or whatever it is called) is less than 2 inches from the fender wall.
![]() Join Date: Jul 2004
My best plan is to get some 1/4 in barrel clips and put in the holes, then the emblems just push on from the outside. I think you can get them at NAPA. These are the same clips that hold the center tailgate trim on above the handle.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
![]() Last edited by BarryB; 11-30-2006 at 06:35 PM. |
