Old 11-30-2006, 04:20 PM   #1
my67C10
my67C10's Avatar
what do you think of this electronic ignition?
does anybody have any experiance with this distributor and if so what do you think of it? http://cgi.ebay.com/ebaymotors/NEW-S...QQcmdZViewItem
my67C10 is offline   Reply With Quote
Old 11-30-2006, 04:58 PM   #2
Rick Mills
Rick Mills's Avatar
Re: what do you think of this electronic ignition?
On the positive side: It's RED - Looks like MSD. $40 isn't that much. You can carry your already working HEI with you in case this one breaks down <assuming you already have one - which puts out about the same voltage>.
On the negative side: The add doesn't say it is MSD or any other recognizable brand, thus the need to 'test every one before it leaves the shop'. Testing only assures it's working when it leaves - no guarantee it will work for any extended period of time.
SMALL PRINT - Returns are not accepted.
$40 + $15 shipping (any handling fee's?)= $65. Take that money and buy a hi-per coil for your HEI <assuming you have one - or have a buddy willing to give you one>. You'll be money ahead... maybe even have change for other goodies.
General rule of thumb with electrical stuff - "You get what you pay for"
The Fastor Pastor
'68 swb, 447 BBC/ 6-71 Weiand, Dual 950 Bigs Carbs/ 2 1/2" Header tubes - 4" collectors/ M-21 4speed:
'70 swb; TH-400 - bagged & shaved. Looking for new engine or parts.
Wife - Original {A Real Classic!}
Rick Mills is offline   Reply With Quote
Old 11-30-2006, 05:10 PM   #3
BowTieOgre
Im about to get mine in the mail from a seller named Skipwhite. Theirs look the same as the one you are linking to and has a 3 year warranty. The Ebay item # on the one I am getting is 260056134599. Check them out.
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 11-30-2006, 05:29 PM   #4
Rick Mills
Rick Mills's Avatar
A guarantee is nice. Means they believe in what they sell.
Get them to tell you who makes it.
If it's from MSD it's probably a BLEM; may be that it didn't pass MSD standard testing. For street use, it could be just fine.
If it's made in china or indonesia... it's your money, your choice.
The Fastor Pastor
Old 11-30-2006, 08:59 PM   #5
timcos
Chief Honcho In Charge
timcos's Avatar
I just bought one from White Performance. I am installing it this weekend.
White (Skip White) has a pretty decent reputation. I am sure he is not selling me any crap...also mine is a daily driver and does not deserve a $300 dizzy.
1992 1500 4x4 Shortbed
1984 Ford F250 Supercab Longbed 6.9L Diesel
1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
1967 C10 SWB (1980-1981)
1971 C10 LWB (1998-2004)
timcos is offline   Reply With Quote
Old 11-30-2006, 09:27 PM   #6
lpaine
lpaine's Avatar
I was looking at other vendors on ebay selling dizzys and at least one made a statement that the 65,000 volt output some sellers claim is bogus. Don't know if thats true, but I thought I'd pass it along.
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart
1998 Chevy 1/2 ton ex cab V-6 5 speed
1967 Chevy SWB - project truck; not started just yet
lpaine is offline   Reply With Quote
Old 11-30-2006, 09:44 PM   #7
Draggn66
Wrenchin & Sandin!!!
Draggn66's Avatar
I got mine from Summit for $85.
http://store.summitracing.com/partde...5&autoview=sku
May not be an expensive one but works for what I need.
Randy
Shorewood, IL.
My Favorite eBay Searches
My Driver Restore Thread
1971 C10 Longbed
2005 Silverado Shortbed
2005 FXDWG
Draggn66 is offline   Reply With Quote
Old 11-30-2006, 09:56 PM   #8
Sweet72
Sweet72's Avatar
I'd be a little leary of that HEI. Some of the guys on a hotrod site that I frequent have had good luck with this one so far...http://cgi.ebay.com/ebaymotors/PROCO...60229442QQrdZ1
Made in Australia (I believe) by Pro Comp.
I like that Summit distributor Randy (Draggn66). Looks like a GM unit, not all shiny machined and polished.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 11-30-2006, 10:05 PM   #9
jacobs
jacobs's Avatar
The gap of your spark plugs will govern the peak voltage that a HEI or conventional points type ignition can achieve. If you have an ignition that is capable of acheiving 1,000,000 volts won't be of any advantage unless the plugs are gapped much wider than stock.
jacobs is offline   Reply With Quote
Old 12-06-2006, 12:53 AM   #10
my67C10
my67C10's Avatar
i dont see a shipping charge, is it free shiping?
Old 12-06-2006, 01:01 AM   #11
skokie
skokie's Avatar
Its at the bottom. 15.00$ UPS Ground
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 12-06-2006, 02:32 AM   #12
timcos
timcos's Avatar
...OK...just finshed the dizzy install.
Bought it from Whites Performance...
Dizzy - $45
Custom mega fire wires - $25
12 ga wire and inline fuse - $10
My two hours worth of work - $360 (glad I did not have to actually fork that out to me)
Increase in power...priceless.
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
Old 12-06-2006, 02:38 PM   #13
Myself
It's probably one of those MSD or MALLORY knockoffs from Australia. Not much better than a stock HEI. Spend the $130 and buy a Mallory with all Mallory performance guts.
Myself is offline   Reply With Quote
Old 12-06-2006, 03:19 PM   #14
wolfthing2000
Don't waste money! Buy the MSD.
wolfthing2000 is offline   Reply With Quote
Old 12-06-2006, 03:57 PM   #15
BowTieOgre
Dizzy - $45
I installed my Whites Performance dizzy this weekend and noticed a marked improvement in performance. It wasnt an OMG moment but it managed to make me say "sweeeeeeet". Im buying another one for my Dad's ride for Christmas.
I'm happy saving a few $$ by buying no name from a reputable seller.
Old 12-06-2006, 04:03 PM   #16
jimmydean
jimmydean's Avatar
I have gotten a fer thing from White Performance and all have been great. I am also getting this setup as my HEI is old. i will keep it as a backup should this one crap the bed.
jimmydean is offline   Reply With Quote
Old 12-06-2006, 08:20 PM   #17
71chevytruckguy
71chevytruckguy's Avatar
im runnin the setup from skipwhite in my daily driven '69. no problems with it and it works great. its by a compnay called warp. probably from china but it works. a whole lot better than the points i was runnin. i'd recomend them. chris.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
