Old 11-30-2006, 05:35 PM   #1
Rokcrln
Rokcrln's Avatar
Tilted (hood tilt build thread)
Well it is not a new idea but I needed a new hinge set up to clear my front tires when the airs out and the frames down. I will be doing a write up for others that want to do this to their truck. I have only the front mocked up right now and I am headed out to built the rear slider latches. This step is one I have not seen any other person complete and post pics of so we will see how it goes. Wish me luck, I want to have it finished up tonight for the mock up stage then I can build the final mounts and give dimentions.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 11-30-2006, 06:13 PM   #2
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
Re: Tilted (hood tilt build thread)
Awesome! can't wait for you to do a write up
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
Old 11-30-2006, 06:21 PM   #3
Rokcrln
Rokcrln's Avatar
The factory slider/hooks work great Now I just need to pull it all back apart and build the final mounting brackets and clean everything up for viewing
Kevin
LFD Inc.
Old 11-30-2006, 06:25 PM   #4
smbrouss70
smbrouss70's Avatar
I've been wanting to do the exact same thing! Now I'll know how a "Professional" does it.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 11-30-2006, 06:54 PM   #5
jugernot
Life, Be In It.....
jugernot's Avatar
Wow you did all that since I lelt earlier today. Nice
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 11-30-2006, 07:11 PM   #6
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
So how much is this kit gonna run me?
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 11-30-2006, 11:01 PM   #7
Rokcrln
Rokcrln's Avatar
Thanks guys I will be building the finish brackets in the morning and try and have it done before quiting time. It will almost be a full bolt-in kit. It will require Two pieces to be welded to the radiator support and 2-4 nuts to be welded to the front brace of the hood. I will make templete's of all the parts for later use. As of now I do not plan on doing any kind of a kit for sale but I would like to do a write up for the board.
Kevin
LFD Inc.
Old 11-30-2006, 11:05 PM   #8
krue
Designated A-hole!
krue's Avatar
A write up will be well appreciated.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 11-30-2006, 11:21 PM   #9
Bob Moore
Do you think any dimensions would have to be changed for a 67/68 front end? Is the front underside of the hood different on the 67/68 hood?
TIA - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 11-30-2006, 11:32 PM   #10
Rokcrln
Rokcrln's Avatar
TIA - Bob
This is a 67-68 front end! Now if you ment 69-72 then no I do not know yet if it is the same. I plan on doing one for my 70 2wd Blazer as well but that will not be for some time.
Kevin
LFD Inc.
Old 12-01-2006, 12:21 AM   #11
Shane
Shane's Avatar
I would love to see / have a copy of your templates for the mounts (front & rear).
This is the mid 80's Buick LeSabre hinge and latch, right?
Shane is offline   Reply With Quote
Old 12-01-2006, 07:18 AM   #12
sixty8c10
MY EX DRIVES A BROOM
sixty8c10's Avatar
i gotta get in on this
They say nobody's perfect.
I'm a nobody, so I must be perfect.
Building Nemo -1968 C10 Long Bed
FRED -1947 KB-2 International
sixty8c10 is offline   Reply With Quote
Old 12-01-2006, 09:29 AM   #13
dan468
dan468's Avatar
Question: are you still going to use the factory truck front latch as well?
dan468 is offline   Reply With Quote
Old 12-01-2006, 10:28 AM   #14
Rokcrln
Rokcrln's Avatar
I am goint to try it first and see about doing a remote latch off of it but may end up using a different style. The stock one will work fine because the hood movement is just like stock for the first 6" of opening. It really is cool because it starts off just like stock then rolls forward about 12" then just tilts up and over the front grill
Kevin
LFD Inc.
Old 12-01-2006, 11:50 AM   #15
Simonstrucker
Big Block Short Bed Stepside
I got 1 for you Rok how about a complete flip front end like this with out the cut on the the middle of the front rear portion of the fender like the fiberglass kit.
Simonstrucker is offline   Reply With Quote
Old 12-01-2006, 12:24 PM   #16
Rokcrln
Rokcrln's Avatar
Nope I can not stand that look, and it is a pain in the arss to work on a tilt front end car. Most of what I build has a good reason behind it like this hood. Now I can go even lower than before with out my tires rubbing
But if you want to do a flip frontend without a fender seam you will need to have your front pivit lower than the rear bottom portion of your fender so when it starts to lift tehfirst action is forward and away from the body and not into it. For this reason it would only work out ok on a 4x4. Here is a quick pic. The pink line shows the pivit point that will pull the fender away from the door as soon as it starts to lift but needs to be low to the ground. The blue color shows how if the pivit is raised up the fender will run right into the door as it lifts. This is why you see fenders cut at an angle and a raised up pivit piont on 2wds. Not to mention your cowl would need to be modified to work as well. Hope this clears things up
Kevin
LFD Inc.
Kevin
LFD Inc.
Old 12-01-2006, 01:48 PM   #17
Bob Moore
Kevin - My BAD. Looking back I can clearly see the 68 GMC hood. I apologize for making you waste your time replying to my stupid posting. If I had opened my eyes in the beginning this would not have been necessary.
Sorry - Bob
vac, 454, T400
more to follow
Old 12-01-2006, 02:02 PM   #18
72CSTC5
72CSTC5's Avatar
Kevin, I wanted to cry when I saw that brand new 68 hood cut on the underside.!!!!!! Looks good.
72CSTC5 is offline   Reply With Quote
Old 12-01-2006, 03:09 PM   #19
Rokcrln
Rokcrln's Avatar
What cut are you talking about? Their are two small tack welds on this hood and that is it! The rest is a bolt on deal I will show more pics tonight as I finish it up.
Sorry Bob~ No problem, now people know it may not work on a 69-72 as it is curently built! All's good
Kevin
LFD Inc.
Old 12-04-2006, 01:10 AM   #20
dan468
dan468's Avatar
have you gotten everything all buttoned up yet? Sounds like it's going pretty smooth!
Old 12-04-2006, 03:41 AM   #21
68GMC454
THE VILLIAGE IDIOT
68GMC454's Avatar
i like it..great idea..cant wiat to see the write up..but how do you open it..but dont wory abotu an answer i know you will show it later on..great work by the way..
billy
honestly honey,,i have no idea how that truck got here.
68GMC454 is offline   Reply With Quote
Old 12-04-2006, 08:40 AM   #22
Rokcrln
Rokcrln's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=218253
Here it is, I posted it in the blazer forum since it is a bit slower I had time to get it all on here before people started responding. As far as opening you just use your stock latch
Kevin
LFD Inc.
Old 12-05-2006, 10:48 AM   #23
Simonstrucker
Rok why do you feel that a complete flip frt would be harder to work on. I want to do this as it would alllow easy accese to the motor if done properly like an 18 wheeler. I would be will to work some thing out with you if you would be intrested.
Old 12-05-2006, 04:27 PM   #24
crazy longhorn
Fabricate till you "puke"
I guess i would ask the same ? I am running a split tilt (steel), & really think that tune ups, repairs, ect are much simpler. shes a little crude....hood pins under the fenders to hold the mess shut, no hydraulics(manual lift only), but here are the pics....
http://community.webshots.com/user/hotrodhorn L BTW....damn nice work on that hood!
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
