Old 12-01-2006, 12:39 AM   #1
Slammed70
Slammed70's Avatar
Metal bed floor....
I know they're out there....Ive seen them, I just cant find them.
My truck is also my daily, and I use it like a truck. Problem being that my factory wooden bed is rotted out so bad I cant put anything in it. And since my dad wont move his 56 (Gasp!) Ford out of the garage....my truck sits out by the curb in the elements.
So is there any one that makes a metal bed floor or know if any of the newer bed floors will fit?
Its a 70 SWB.
Thanks,
Mitch
Slammed70 is offline   Reply With Quote
Old 12-01-2006, 01:54 AM   #2
Aarons72s
Re: Metal bed floor....
They arent made new yet. Your best bet is to find a good used bed and swap yours out or find one with a good floor but wasted sides or find someone who is removing a steel floor for a wood floor. Finding a swb steel floor is pretty hard and when you do they go for alot of $$$$. You could shorten a long bed floor but is not recomended. So really your best and most cost effective one is to replace the wood floor with a new wood floor. Just seal the wood with epoxy and you should be fine. That is what I would do.
Aarons72s is offline   Reply With Quote
Old 12-01-2006, 03:41 PM   #3
motocrosschump
Put some Diamond Plate down
2006 Titan SE Crew Cab Daily Driver
2005 Mazda Tribute (Wifes car)
1969 C10 SWB 350/3 Fleet "Max"
1969 Chevelle 2 door 350/3
motocrosschump is offline   Reply With Quote
Old 12-01-2006, 03:53 PM   #4
67ChevyRedneck
67ChevyRedneck's Avatar
You'll have to swap your front bed panel for it to be "right" too.
You can also just put a sheet of plywood down for now. That's what my stepside had in it when I bought it
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 12-01-2006, 04:24 PM   #5
dennislbrooks
dennislbrooks's Avatar
You can buy the 2 halves for 73-87 --- I might try that route if you can fabricate a little.
dennislbrooks is offline   Reply With Quote
Old 12-01-2006, 06:01 PM   #6
lilred67
lilred67's Avatar
i installed 3/16" sheetmetal in my stepside bed......i think there are some pics on the board somewhere......i'll try to find them
http://67-72chevytrucks.com/vboard/s...ighlight=floor
here they are!!!!!!!!!
lilred67 is offline   Reply With Quote
Old 12-01-2006, 08:02 PM   #7
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
Arrow Re: Metal bed floor....
I have a very good metal 67 short wheelbase floor I am gonna get rid of I am going with the wood because of the look , I will not be hauling much more than my vintage coca cola cooler so the wood will work for me , my metal floor is the best one I have ever seen in my life with only very very minor rust in just a couple spot's , all the cross sill's are super clean it looks nice and clean underneath as well , I would gladly trade it to a member here for some wood floor parts such as a good rear crosmember and all the sill's in super clean shape for a wood floor and ???
anyone that see's this before they delete it feel free to PM me ,
19673ontree is offline   Reply With Quote
Old 12-02-2006, 06:22 AM   #8
Hart_Rod
Hart_Rod's Avatar
Has anyone tried to use one out of a later model truck????
Hart_Rod is offline   Reply With Quote
Old 12-02-2006, 09:12 AM   #9
I would go with Hart_Rod suggestion. Find a late model, cut the floor to fit, then bolt/weld it in. However, as was mentioned, to do it right you'll need a new front panel (or modify the old one). Also, to keep body lines correct you'll need different (or modified) cross braces to make up the bed thickness differences.
Old 12-02-2006, 10:02 AM   #10
COBRO
Active Member
www.tabcobodyparts.com list left and right bed floor panels for 67-72 PU. $91 each side. This is the only place Ive found that list metal bed floors for our trucks.
HTH::CB
COBRO is offline   Reply With Quote
Old 12-02-2006, 10:25 AM   #11
19673ontree
CAN'T FIX NOTHIN
here is the one I am gonna let go ,,
