Old 12-01-2006, 01:11 AM   #1
Hurdy
Trailing arm bushings
I have a 67 C10 that I have tore down to the frame. I tried to knock the trailing arm bushings out of the trailing arms but they will not budge.
Any help or ideas would be greatly appreciated.
Thanks,
Hurdy
Hurdy is offline   Reply With Quote
Old 12-01-2006, 10:22 AM   #2
byrd
Union Electrician
byrd's Avatar
Re: Trailing arm bushings
You are going to have to take them to a machine shop and have them pressed out and the new ones pressed in(just had this done myself). GM still sells the trailing arm bushings.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 12-01-2006, 10:29 AM   #3
Ram-Man
Ram-Man's Avatar
If you torch out the rubber part you can install the poly ones in your old steel sleeve because the poly ones use your existing sleeve. This way you can do it yourself. Otherwise like Byrd said they do need to be pressed out.
Ram-Man is offline   Reply With Quote
Old 12-01-2006, 12:49 PM   #4
Hurdy
Thanks for the help, I'll fire up the torch.
Hurdy
Old 12-01-2006, 05:20 PM   #5
Shane
Shane's Avatar
I did mine with a big ass hammer and a socket ... and I am a machinist & have access to a press ... go figure.
Shane is offline   Reply With Quote
Old 12-04-2006, 10:57 PM   #6
geology rocks!
geology rocks!'s Avatar
I just replaced mine this weekend. Easiest way to do it yourself it to drill a bunch of small holes through the rubber and then pop the whole thing out with a hammer and large punch. Just make sure not to hit your outer sleeve. I then greased up the new bushings and used a C clamp to press them in. Worked great!
geology rocks! is offline   Reply With Quote
