Old 12-01-2006, 03:09 PM   #1
Solver
Solver's Avatar
heater hose placement
Radiator went bad today and have a replacement but it doesn't have the heater hose nipple on the radiator like current one does
Need to hook up one heaterhose to waterpump instead of the radiator.
Does it matter which port I use on the water pump?
There is a side port and a top port. I would prefer to use the side port but it is a square plug end and after this long I am not sure if it will even come out.
The top port has a reducer and a plug that I amm sure I can break loose.
Are they both ouputs cause the other hose goes into the top of intake manifold
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 12-01-2006, 04:18 PM   #2
Aarons72s
Re: heater hose placement
Side one is the one you are supposed to use. You will also need to find a long pipe nipple to install there, most are to short. Not sure about the top port.
Aarons72s is offline   Reply With Quote
Old 12-01-2006, 07:03 PM   #3
Green Machine
Green Machine's Avatar
The water comes out of the intake and is returned to either the radiator or the water pump. I am pretty sure the top fitting on the pump is a "suck" port also just like the side one. I have a spare fitting that goes in the side of the pump, if you want it just let me know, I'll drop it in the mail.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 12-01-2006, 08:23 PM   #4
Blue85
Oilfield Trash
Blue85's Avatar
top or side nipple on the pump will work fine, just about every 350 i have owned has had the heater hose on the water pump
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 12-01-2006, 09:13 PM   #5
Sweet72
Sweet72's Avatar
Most auto parts have long and short heater hose nipples similar to the one pictured above. Mine also uses the pump side port and the other hose to the intake. Make sure to use teflon tape or pipe dope on the threads.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 12-01-2006, 11:15 PM   #6
Solver
Solver's Avatar
didn't know if there was a pressure and return side on waterpump.
Thanks for the offer Green Machine but the reason I had to go to the top port was cause the plug on the side is a square head and I couldn't get a enough bite with a socket to break it loose. It is 1/2" square but I couldn't fit a 1/2" drive socket reversed on it either. no room for a pipe wrench and it was to cold to pull the whole pump to try and get that side port off. For now I'll just have the pipe run into the top till I can figure a way to remove the side plug. Kind of sounds like a spring thing
Old 12-01-2006, 11:26 PM   #7
Green Machine
Just went out to the garage and verified this. An 11/16 - 12 point socket fits the 1/2 in square plug pretty well, might be able to get it that way, just an idea......
Old 12-02-2006, 01:10 AM   #8
Solver
Solver's Avatar
Thanks for the extra input tom but the 11/16 12 point is just big enough to slip on the corners. Real nuckle buster if you know what I mean.
Old 12-02-2006, 09:44 AM   #9
Olden Days
Living In The Past
Olden Days's Avatar
sears has 8 point (craftsman) sockets that oughta work
Olden Days is offline   Reply With Quote
