Old 12-02-2006, 01:21 AM   #1
wakeboarddrumma
wakeboarddrumma's Avatar
Sanding inside of bed
I am going to be needing to do this sooner or later, what's a good way to do it? I don't have a sand blaster, and i can only get the tops of the slats with a belt sander. Heres a picture of what i'm working with
wakeboarddrumma is offline   Reply With Quote
Old 12-02-2006, 01:34 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Sanding inside of bed
A wire cup on a 4 1/2" grinder should work good for that. (wear safety glasses)
LockDoc
Leon
Old 12-02-2006, 03:04 AM   #3
Rollie396
someday it will be done!
Rollie396's Avatar
A face shield would be a good idea actually.The cups aren't as bad as the wheels,but they will throw wires and they don't feel good stickin out of your nose or lip.Oh and wear jeans and mebbe covies as well to keep from getting dinged in some very bad places.....
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore.
'80 LWB 2wd beater
'67 GMC long fleet (cab donor)
'66 long step (parked till it's turn comes around)
'65 short step (parts truck that will donate it's bed and possibly frame to the '66)
'06 Grand Prix wife's car (she hardly lets me touch it)
my pics
Rollie396 is offline   Reply With Quote
Old 12-02-2006, 08:42 AM   #4
Sweet72
Sweet72's Avatar
That bed looks like it's barely broken-in! You should see mine. If you want to go down to bare metal, use paint stripper first to get all the paint off, and then some naval jelly and water or oxysolv with a scotch brite pad working in small sections till all rust is gone! Easier said than done.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 12-02-2006, 08:52 AM   #5
70GMCer
70GMCer's Avatar
What I did on mine was to just scrape away the loose rust and then put a coat of Eastwood's Rust Encapsulator. You can either spray it or brush it on. I brushed mine. After that I went and bought Dupla-Color bed liner kit, and put 2 coats on. Looks great and don't have to worry about the rust. You can also use POR-15 if you want.
steve
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 12-02-2006, 01:00 PM   #6
highboy_04
highboy_04's Avatar
LockDoc
paint wont stick to buffed metal. and if you want to bed line it i suggest using herculiner. i've had good luck with it and it is really tough and pretty cheap. that duplicolor stuff is basically paint with sand in it.
'67 c10 350/th350
highboy_04 is offline   Reply With Quote
Old 12-02-2006, 02:05 PM   #7
LockDoc
LockDoc's Avatar
The paint is still adhering to mine after three years.... Maybe because I used epoxy primer?? Dunno...
LockDoc
Leon
Old 12-02-2006, 02:49 PM   #8
roj2323
pay a guy $50-75 and have it blasted. you can sit and drink while they do all the work.
you see there is this rule i live by it's weird but it totaly makes sence.
there are 3 things to concider when doing anything time money and quality. no matter which 2 you choose the 3rd will suffer. for the small amount of money it will cost you it's worth saving the 2 days of work to sand the bed down.
fast with quality will cost you money
cheap with quality will cost you time
fast and cheap will affect quality
roj2323 is offline   Reply With Quote
Old 12-02-2006, 02:55 PM   #9
72CSTC5
72CSTC5's Avatar
You could do like the guys said and unbolt the bedside and cut the small weld in the back near the floor, remove the tailgate and front box panel and just send the floor to be blasted front side and back and then metal wash and metal condition the metal followed by self etching primer and then a good 2k primer to fill in the small divots left from the rust, sand smooth and paint and then coat the underside with paint or undercoating and put the bed back together, orrrrrrrrr, 3M roloc strip disc strip the bed in all of the grooves and crannies with a die grinder and compressor. Much easier I think. Good luck
72CSTC5 is offline   Reply With Quote
Old 12-02-2006, 03:10 PM   #10
roj2323
i wouldn't even disassemble the bed... any good sand blasting guy will prep so the sides don't get blasted. i imagine though that if he's refinishing the bed floor that the rest of the inner bed is going to get refinished as well so it really doesn't matter as long as carefull attention is paid to the panel joints during primer prep.
Old 12-02-2006, 03:11 PM   #11
72CSTC5
72CSTC5's Avatar
I just do not like it when the sandblasting send gets under all of the edges and either blows out when you paint or stays there to feed rust.
Old 12-02-2006, 04:13 PM   #12
cdowns
cdowns's Avatar
if time isn't an issue and money is you can make an inexpensive sanding block out of a 2x4 and tack and glue a 1/4thick by 11/2 wide piece of trim molding to the 2x4 and wrap it with 100grit sandpaper to start and sand away// it shouldn't take more than a weekend it's crude but effective
Old 12-02-2006, 05:23 PM   #13
wakeboarddrumma
Yeah, i'm doing the work myself, that's the way i did the cab. I sanded it all down, took about 6 hours strait, and then I began priming it.
I am hoping this won't take quite as long. But i don't care if it does. I should be doing it within the next month.
Old 12-02-2006, 09:34 PM   #14
Huck
Huck's Avatar
Pour about a garbage pail load of loose gravel about a 1/2 inch in diameter--let in slide and roll around back there for a few weeks. It will loosen any rust. then just sweep it out ----done! hehehehehe
Huck is offline   Reply With Quote
Old 12-02-2006, 09:56 PM   #15
Shane
Shane's Avatar
Chemical stripper, some Saran Wrap, a few hours and a water hose and it's bare metal.
Brush the stipper on ... cover with Saran Wrap (or a garbage bag - this keeps the stripper from drying out before the paint lifts) ... let stand for 15-20 minutes ... remove Saran Wrap ... apply more stripper ... recover with Saran Wrap ... let stand for 15-20 minutes ... rinse with water hose.
Let dry and repeat until most traces of paint are gone or at the very least loose.
Hand sand with 80 or 100 grit paper the remaining small sections of stubborn paint.
Prime. Paint. Stand back, open beer and admire your hard work.
Shane is offline   Reply With Quote
Old 12-03-2006, 01:11 AM   #16
timcos
Chief Honcho In Charge
timcos's Avatar
Fast Cheap or Perfect. Pick Two.
1992 1500 4x4 Shortbed
1984 Ford F250 Supercab Longbed 6.9L Diesel
1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
1967 C10 SWB (1980-1981)
1971 C10 LWB (1998-2004)
timcos is offline   Reply With Quote
Old 12-05-2006, 03:44 AM   #17
Brad
Out of the carpool lane.
Brad's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=181633
Somewhere in my project I did the same thing and used a wire cup then used the paint on bedliner crap. I have a tonneau cover but mine holds up well.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 04-10-2010, 12:21 AM   #18
gmc1971harwich
gmc1971harwich's Avatar
im going to use the chemical stripper myself on my bed but where do i get it locally? theres no body shop supply places around me
gmc1971harwich is offline   Reply With Quote
Old 07-11-2010, 05:13 PM   #19
SRVBLUES64
Head over to Home depot there a blue abrasive wheel in the tool section call the paint stripper I think, for 9 bucks it goes on you 4.5 grinder and it will strip the paint off in minutes buy 2 for the bed it will not heat up the metal it kind of looks like a sponge good luck
SRVBLUES64 is offline   Reply With Quote
