12-02-2006, 01:44 AM | #1 |
hi everyone..heating ???
Cant get any warm air in the cab. Truck can run for an hour and all i get is very luke warm air outta the floor vent and one of the dash vents the other is not blowing at all. Any ideas....
1971 Chevy C-10 . |
12-02-2006, 02:11 AM | #2 |
Junior Member
Re: hi everyone..heating ???
Are you low on coolant?
DAN 69 CUSTOM 10 LWB: |
12-02-2006, 02:33 AM | #3 |
Registered.........
Thermostat stuck open, missing, or rusted out - how long has it been since it was replaced?
1966 C10 panel-400 small block/TH 350 combo Nothing is fool proof to a talented fool! Popcorn: Pops at exactly 444 degreese Expands to 44 times it's original size Has a 4 year shelf life |
12-02-2006, 03:02 AM | #4 |
Oilfield Trash
factory A/C truck? If do is your heater valve stuck? If not, your heater core is likely plugged with leaves and other junk
14 Dodge 3500 Mega Cab 08 Dodge 3500 Mega Cab 87 Chev 3+3 4x4 80 GMC K10 High Sierra bone stock 70 Chevelle 350SS long term project 68 GMC 3ton Grain Truck/Garbage wagon 50 Pontiac 2 Door Coupe Project "I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr. |
12-02-2006, 03:07 AM | #5 |
4 eyed fever
As far as the dash vents, sounds like some of the tubing is missing or came apart.
1971 GMC 2500 4x4 1972 GMC Sierra Grande 1/2 t 4x4-#1 son's truck. Recently completed resto. 4 YO daughter," Daddy, I like your truck better than Mom's." (2000 F350-ranch truck) Smart kid!! Last edited by al's71gmc; 12-02-2006 at 03:07 AM. |
12-02-2006, 07:46 AM | #6 |
removing the blower motor then the heater core and cleaning out the 35years of crap out of the housing will help// and inside the cab checking the diverter box to see if the cheap ass factory flapper is busted and also replacing the ductwork if needed // putting a new 190degree thermostat in // do all that and you should have plenty of heat
12-02-2006, 09:43 AM | #7 |
laying low
Feel the hoses going to and from the heater core. If one is hot and the other is cold there's likely an obstruction. If both are cool the thermostat may be missing or stuck open. Check under the dash for loose or missing, broken hoses and broken or disconnected cables.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
12-02-2006, 12:14 PM | #8 |
Questionable
Like everyone else said -
- Check your hoses for heat at running temp, heater core might be stuffed. - Check your coolant level in the case your heater core is leaking. - Check your blower (round cylinder next to fender inside engine bay) to see it blowing. - Check all hoses inside the truck connected to the black box under the dash/radio - There is a steel flap behind the heater core assembly, it may not be opening and closing as necessary. I'm curious if there is a newer model vehicle's heater core and blower motor combo that would work with our trucks ....
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
12-02-2006, 08:03 PM | #9 |
I am a Referee of life.
My heater valve would not open.The dash lever moved and everything else seemed to work but I had Mrs.P move the lever and watched for movement from the valve.It only opened about 1/8 of the way.Slightly warm air.When I manually opened it it got hot quick.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
12-03-2006, 09:12 AM | #10 |
Where's my beer?
My money is on stuck open or missing thermostat. That's definitely where I'd start, it's cheap and easy to fix.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
12-03-2006, 12:23 PM | #11 |
Questionable
I would believe the thermostat was stuck open if the engine temp was not getting very high, but I didn't see where the original poster said what the temp at idle was. Cheap and easy fix is the one that doesn't cost any money - check the flapper on the firewall
12-05-2006, 03:23 AM | #12 |
Out of the carpool lane.
I think someone here has used a Cadillac blower motor that fit right in place.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
12-05-2006, 09:44 AM | #13 |
Questionable
S10 blower fits there too, from what I gather.
I'm really interested in finding something that would be a direct boltup that isn't nearly as bulky as the stock unit. I remember my mid-to-late 80's GMC S15 had the heater core inside the car, IIRC. I would love to find a similar setup for this truck. Blower on the outside, blows air inside, over the core, then whammo, hot air.
12-05-2006, 10:28 AM | #14 |
In the same way minerals clog a radiator core, minerals can also clog heater cores. Backflushing a heater core will get rid of loose sediment but won't get rid of hard mineral deposits. NEVER, NEVER use tap water in a cooling system. Tap water is full of minerals. Use only distilled water.
