12-02-2006, 02:46 AM | #1 |
Advantages of replacing throttle body?
My best bud came home from the Army today
Anyway, after shooting the **** for a little while, he insisted I jump in his Blazer and go for a spin. Long story short, it suddenly has balls and big ones at that. The motor has really woken up. He says his old man put a new throttle body on along with a spacer. The injectors are fairly new as well, they were replaced in June I believe. Would replacing a throttle body really make that much of a difference? |
12-02-2006, 12:07 PM | #2 |
Re: Advantages of replacing throttle body?
hello,,it can make a big difference in certain case's.had one that was running like crap,tried everything,took the t-body off,replaced ran like a champ,,had already had it off a couple times but never noticed a hair line crack from one of the bolt holes that ran clear into the bore,,was sucking air bad..
12-02-2006, 02:02 PM | #3 |
I was just wondering, because I know his old man is a trickster. He'll tell you he did one thing, just to cover up what he really did.
12-02-2006, 04:47 PM | #4 |
Chevys Kick A$$
LOL, thats great. I know it will help but I don't know about getting major balls from doing a new throttle body and a spacer, should definantly pick up the pace but it might also have really needed a new throttle body in the first place so doing it might have helped more then it usually would.
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
12-02-2006, 04:53 PM | #5 |
Well by major balls I mean running like a fresh V8 should. It was a dog before, and mine still is.
12-03-2006, 07:10 PM | #6 |
did he replaced it with a rochestor or a holley ? i bought a holley replacement 670 cfm a couple years ago for my ' 89 silverado with a 350 .i cut out the intake manifold bores and added a helix spiral spacer and it woke it up .yet i modify the bracket for the cables to raise them up an inch and get fuel line extensions ,but it was all worth it. like its a totaly different motor. i also bought a air intake kit i use in the warmer months and then the stocker with a jegs air tube in the winter. the holley's have also a different regulator and injectors over stock .i believe, correct me if i'm wrong , the stock body is rated 390 with 1 5/8 " bores . where the holley ones have big 2 " bores same as the stock 454's . just after that i bought a 3" cat back exhaust kit( where i have three inch pipe where the cat should be ) , it works out real nice . by the way , i have an accel coil and ignition module
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car |
12-03-2006, 07:12 PM | #7 |
second pic of bracket
