Old 12-02-2006, 11:03 AM   #1
pkj
electric fan sending unit
i am installing a pair of electric fans on my 68, 305-v-8, performer rpm intake. i dont know what size thermostat to use or what to do about sending unit for fans. what size, or rating? location to install? please help. i want the fans to work only when needed not full time. this is a pair of fans out of a late model gm, 97 iroc? ls1? not sure. since i dont know the specs i think i should set them up on seperate 30 amp relays? thanks, pkj
pkj is offline   Reply With Quote
Old 12-02-2006, 11:12 AM   #2
kelsfine69
18 Till I Die
kelsfine69's Avatar
Re: electric fan sending unit
heres an idea
http://www.flex-a-lite.com/auto/html...cessories.html
i got the #31147
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 12-02-2006, 11:23 AM   #3
pkj
thanks. wonder how reliable that is. pkj
Old 12-02-2006, 12:10 PM   #4
shifty
Questionable
shifty's Avatar
Most of the fan companies provide them. Mr Gasket has a kit, so does Flex-a-Lite. Both of these can be bought ~90 minutes up the road from you at the Summit superstore (Exit 216 on I-75, on the east side of the Interstate).
They are supposed to be really reliable. They're sold in a lot of the fan kits out there. In fact, you can probably find a full fan wiring kit (including relays) - hit Summit's site and poke around www.summitracing.com or try going to the flex-a-lite or Mr Gasket sites if you can't find something @ Summit.
Word of advice: Call ahead of time w/Summit before you drive there - make sure the part is in stock. I've done two trips now only to find my part is not there
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 12-02-2006, 02:16 PM   #5
Mudder
Mudder's Avatar
I got mine from Jegs.
Mudder is offline   Reply With Quote
