Old 12-02-2006, 03:24 PM   #1
ratrod67
ratrod67's Avatar
1972 Cheyenne for sale or trade
1972 Chevy Cheyenne
Motor:454 .60 468 ci
cast crank turned .10 .10
Shot-peened rods with ARP bolts
Speed-Pro coated pistons
Comp Cams 282 solid cam with Comp Cams lifters and pushrods
Lunati roller thrust bushing
Cloyes double roller timing chain
Mini starter
TCI flexplate with ARP bolts
Oval port heads with hardened seats, 3 angle valve job
Manley valves 2.19 and 1.88
Crane Gold roller rockers 7/16 stud
Edelbrock Airgap intake
Moroso Billet valve covers
Full MSD ignition with 6AL box
Taylor wires
Demon carb
Transmission:
TH350
Full manual conversion
B M Holeshot 3000 converter
B M Megashifter
B M 24,000 GVW cooler
TCI line lock
1 piece driveshaft with new yoke and Spicer Ujoints
Exhaust
Headman coated headers 1 7/8 tube
1 chamber Flowmaster mufflers
3 inch pipe with"H" pipe and dumps in front of axle
Rearend
12 bolt
Richmond posi 4 series carrier
4:10 gears
M/W axles
Fuel system
Holley fuel pump
Holley regulator
RCI fuel cell under bed
Fram filter
Goodyear Hose
Braided from regulator to carb
Cut-off switch for pump mounted into back-up light
Suspension and brakes:
4 wheel disc with CPP rear disc kit
1972 Corvette master cylinder, new booster
Master power prop valve
Stainless hose upgrade
New Emergency brake cables
Fresh brakes up front 5 lug factory disc
DJM 3 inch drop front springs
Chisholm spindles
Chisholm upper tubular control arms
1 ton front sway bar
Rear DJM 6 inch drop springs
Brother adjustable tracking arm
Rebuilt front suspension
Wheels and tires
15X10 rear Centerline Telstars with ET Streets
15X7 front with 245/60 tires
Misc
New 4 core radiator
New carpet and kick panel carpet
recovered seat
New gauge panel
AutoMeter gauges with Playback tach and shiftlight
Kenwood CD with electric antenna mounted in stake pocket
New cab mounts
Spray in bedliner
New wiring
Battery relocated to bed
Sir Michaels steel roll pan in rear
Truck body is in good condition. Minor rust in rockers.
Has speaker holes cut into panel behind seat
Speakers in doors
Paint is driver quality. Has a couple bad places. But still looks good.
Crack in windshield
Has antique plates
I have 20K of reciepts for build
$12,000 or trade
ratrod67 is offline   Reply With Quote
Old 12-02-2006, 03:26 PM   #2
ratrod67
ratrod67's Avatar
Re: 1972 Cheyenne for sale or trade
pics
Old 12-03-2006, 09:29 AM   #3
Gray Ghost
Gray Ghost's Avatar
Very nice truck....what's the key in the passenger tailight do?
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 12-03-2006, 09:44 AM   #4
centsless
sufficiently talented fool
centsless's Avatar
It is the fuel pump disconnect switch
Very nice truck!!!
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 12-12-2006, 09:01 PM   #5
ratrod67
ratrod67's Avatar
Old 12-12-2006, 09:09 PM   #6
jmbstudios
Pickin' and a Grinin'
jmbstudios's Avatar
I thought that was the wind up key..
jmbstudios is offline   Reply With Quote
Old 01-06-2007, 05:25 AM   #7
JTK20
Active Member
Bump for ya.
Somebody needs to buy this beautiful truck so it doesn't get parted out...
JTK20 is offline   Reply With Quote
Old 01-06-2007, 07:34 AM   #8
bgangsta999
The Best Member
bgangsta999's Avatar
Originally Posted by JTK20 View Post
Bump for ya.
DONT PART IT!!!
70 shortbed C10
-------SOLD-------
1972 Chevy C-10 l/b
bgangsta999 is offline   Reply With Quote
Old 01-06-2007, 08:49 PM   #9
DoobieBrother
DoobieBrother's Avatar
Wow. Very nice. I only hope my 68 looks that good someday.
DoobieBrother is offline   Reply With Quote
Old 01-06-2007, 08:54 PM   #10
71chevylowrider
71chevylowrider's Avatar
Good for you dude, don't part it, soemoen will buy & love that truck.
71chevylowrider is offline   Reply With Quote
Old 01-06-2007, 09:06 PM   #11
cypressbog
Go Pack Go!
How much for the black door panels and pads, and the instrument bezel? Figure shipping to 54913.
cypressbog is offline   Reply With Quote
Old 01-07-2007, 04:24 AM   #12
JTK20
Active Member
Oh great, look what I started.
Well before anybody starts hounding ratrod67 for parts, see this thread first
http://67-72chevytrucks.com/vboard/s...d.php?t=221851
Old 01-08-2007, 01:26 AM   #13
bgangsta999
The Best Member
nooooooo!
70 shortbed C10
-------SOLD-------
1972 Chevy C-10 l/b
Old 01-08-2007, 01:55 AM   #14
corn
$12,000 or trade
Sorry, couldnt help myself...
corn is offline   Reply With Quote
Old 01-08-2007, 02:00 AM   #15
pimperout
pimperout's Avatar
very nice indeed
pimperout is offline   Reply With Quote
Old 01-08-2007, 06:13 AM   #16
cypressbog
Go Pack Go!
Originally Posted by cornfed63 View Post
$12,000 or trade
Then the posting should be in the trucks for sale area not the parts forum.
