Old 12-02-2006, 05:04 PM   #1
crosby
crosby's Avatar
how to tell gear ratio?
I am trying to determine the gear ratio on a parts truck I have, a 1978 GMC K35, which has a dana 60 front and 14 bolt rear. I pulled the rear diff cover off, and can't even see the pinion teeth. I suppose I could jack up one side and spin the ring to count those teeth, but then what? I don't see any obvious markings anywhere on the housing, or anywhere on the truck? Thanks guys!
Crosby
1978 Chevrolet K10 stepside
NH
crosby is offline   Reply With Quote
Old 12-02-2006, 05:39 PM   #2
motopatzo
motopatzo's Avatar
Re: how to tell gear ratio?
Quite a few years ago I wanted to find out an axle ratio quickly in a truck with no markings and it was at the seller's home so..........I jacked up the back of the truck (use jackstands to be safe) and marked the bottom of the drive shaft and the bottom of one rear wheel. Spin the drive-shaft one complete revolution while watching the rear wheel that is turning. It should move less than a full turn. If your wheel only moved 1/4 turn from your mark, your formula would be 1 divided by .25 = 4 or in other words 4:1 ratio. Try and be as accurate as you can in counting the wheel movement. This should put you in the ball park.
motopatzo is offline   Reply With Quote
Old 12-02-2006, 05:45 PM   #3
b454rat
Check the glovebox for the rpo codes, if the tag is still there. I've seen them undre the hood too. If neither are there, look for a tag on the front axle, it will be bolted with the cover bolt. It will say the number of teeth and the ratio. If that isn't there, pull the cover and look for the numbers there.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 12-02-2006, 08:58 PM   #4
1969 GMC
1969 GMC's Avatar
it should be stamped on the ring gear. try rotating it around til you can see it.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 12-02-2006, 11:46 PM   #5
crosby
crosby's Avatar
wow thanks guys, lots of good info there. appreciate it, I will let you all know how I make out.
Crosby
NH
Old 12-03-2006, 01:32 PM   #6
magnethead
7000 #'s of american IRON
magnethead's Avatar
K35 dually should be 4.10's. I'm yet to find a dually with 3.73's from the factory.
magnethead is offline   Reply With Quote
