12-02-2006, 06:06 PM | #1 |
OT!! WTF is wrong with my '86 GMC
Okay, just started like 30 minutes ago, driving around town exploring Jacksonville. My truck runs fine while cruising, but as soon as you go to slow down to turn or stop the truck bogs down REALLY BAD. Almost like it has a vacuum leak or something like that, but I havent been able to find anything loose. I messed with it in the parking lot, its weird, when I start it, it starts and runs fine, drop it into gear all normal. Comes out, idles up a hair, just like it always did. REV it UP, and let the idle come back down and its like its only runnin on 5 cylinders or something. The only thing I didnt check for a vacuum leak was the modulator. I could see that maybe because earlier today, I tightened the motor mount bolt on the pass. side... Can anyone help with ideas? I've messed with the timing and made sure all the plug wires are fine and connected... It's a 350 with a performer, 1406 edelbrock... everything ran fine before. Please help folks. Thanks
Brandon |
12-02-2006, 06:15 PM | #2 |
sufficiently talented fool
Re: OT!! WTF is wrong with my '86 GMC
unplug the egr valve and see what it does
"it's impossible to be surrounded by idiots when you are part of the circle" 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board |
12-02-2006, 06:40 PM | #3 |
Not that I'd recommend driving around a lot like this, but unhook the brake booster, plug the vacuum line, and take a test drive.
I've heard of bad brake boosters causing vacuum leaks and even problems with burned valves (from particular cylinders running extremely lean - depending on where the vacuum is drawn from). Probably not your problem, but easy to check. Eric |
12-02-2006, 06:44 PM | #4 |
I think i may do this, my brakes have been having trouble lately. If my truck is idling for a long period of time, my brakes work fine, but under normal driving situations and ANY other time, my pedal goes down about 3/5ths of the way until brakes start to work, thinking maybe MC. May try that soon. Anything else folks? Thanks
Brandon |
12-02-2006, 11:23 PM | #5 |
The Older Generation
I think I would check the line to the modulator too. It sounds like you may have knocked something loose when you were working on it. LockDoc
12-03-2006, 08:49 AM | #6 |
blood type; Retumbo
