![]() Join Date: Mar 2004
Camshaft ID help please
hey guys,
i got my hands on a FREE 350 bored .030 with flat head pistons and i have just about everything ID'd but the cam. i've tried everything i can think of with no luck. as far as i can tell it's not a stock cam and since the engine only had very few miles on it the cam isin't even broken in all the way. if you can help please let me know. here's the number on the back of the cam stamped: 2019 m c thanks, ondrew |
![]() Join Date: Aug 2004
Re: Camshaft ID help please
You could try e-mailing different cam companies tech supprt. That # may be a grind code or stock #. Or, you could get a dial indicator and degree wheel and degree it out for the actual specs if the engine is sitting in your shop.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ Last edited by clay68c10; 12-02-2006 at 08:57 PM. |
yea i might just have to put a dial indicatior on it. i've allready tried all of the major cam company sites.
ondrew |
#4 | |
![]() No clue on the cam - I'd start by going to the major cam company web sites and searching on that number. You're likely to have to diagram the cam lobes ![]() [Whups - just saw your reply - you know how to digram the cam, apologies ![]() Last edited by Billla; 12-03-2006 at 02:17 AM. |
If you have already tore it down, and did not mark where the lifters go on what lobe, I'd just scrap the idea of trying to find out what it is. Once an engine has been fired up, just for a short time, (about 20 minutes), the lifters are then matched to the cam. Mixing them up is not good. You'll wipe the cam out in a very short time. I'd get a new cam and lifter set and be done with it.....
steve
1997 GMC Sierra Ext 1965 Mustang |
i have the lifters stored in order and a full set of new ones as backup. as for just getting a new cam i'd honestly rather not spend $200 i don't have so i was hoping to ID the one that's in it because the only other cam i have laying around is a stock one. as for tearing it down to see what i rally have well it's funny you mention it. i pulled the pan to pull a couple caps to see what it looked like and i found it to be about 10mins from spining the berrings. needless to say i just finished putting the bottom end back together with all new berrings, a freshly cut crank and new rings. even with that i'm only about $160 into it including the gasket set.
ondrew |
