Old 12-02-2006, 10:52 PM   #1
stefan
New Member
drive shaft questions
guys im a former vw fan and now im building a 72 chevy truck,what i want to know is did all short bed chevys come with two peice drive shafts or did some of them come with one peice drive shafts. thamks for any help.
stefan is offline   Reply With Quote
Old 12-03-2006, 08:47 AM   #2
70GMCer
70GMCer's Avatar
Re: drive shaft questions
short or long, they all had 2 piece shafts....
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 12-03-2006, 09:10 AM   #3
see ten
WTB this ad
see ten's Avatar
Sorry, but in my experience a swb that was originally a 6cyl straight shift would have a one piece driveshaft. Now, all of the swb v8 auto trucks I have seen have come with a two piece shaft.
see ten is offline   Reply With Quote
Old 12-03-2006, 12:28 PM   #4
shifty
Questionable
shifty's Avatar
I believe see ten is correct.
my '68 C10 with 3spd (on tree) still has the stock 1pc driveshaft in it.
hello and welcome to the forum from a fellow VW fan my truck, and my dub:
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 12-03-2006, 12:34 PM   #5
1969k10stepside
My 71 K10(4x4) which had a 292 and a Sm465 4 speed had a one piece drive shaft while a swb w/ a 350/th350 had a 2 piece drive shaft.
1969k10stepside is offline   Reply With Quote
Old 12-03-2006, 02:17 PM   #6
smitty62
smitty62's Avatar
OK.......now my question is, I'm repacing a six cyl. W/PG with a 350/TH350. Am I going to be able to use my one piece shaft?
Smitty
Stepsides look like real trucks!
Smitty
smitty62 is offline   Reply With Quote
Old 12-03-2006, 02:27 PM   #7
dave2953
Dave's not here, man
dave2953's Avatar
I believe I remember reading somewhere that a short shaft 350 is the same as a Powerglide as far as length and that their driveshafts can be used interchangeably. Someone please correct me if I'm wrong.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 12-03-2006, 02:38 PM   #8
crazy longhorn
Fabricate till you "puke"
http://www.tciauto.com/Products/TechInfo/trans_dims.asp its close enough to drop in crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-03-2006, 03:46 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
as long as he places the engine in the inline location.
If the TH350 is the short shaft one, then a drive shaft of 4 foot 10 inches (from center of U-joint to center of U-joint) will do the truck on a coil rear SWB with the small block in the correct location and a short shaft TH350.
Old 12-03-2006, 05:07 PM   #10
crazy longhorn
Good point Andy the difference in position is 3 1/2" (+or- 1/8"), going from I6 to sb (factory) position. The short turbo & the glide are very close in measure tho, & do have the same slip yolk(I like it when GM makes chit easy!) crazyAl
Old 12-03-2006, 05:24 PM   #11
kyull67
kyull67's Avatar
I've got a 67 Short stepside that was originally a six cylinder and three speed. My 350 and th350 dropped right in close enough to use the original one piece drive shaft.
kyull67 is offline   Reply With Quote
Old 12-03-2006, 08:40 PM   #12
chevybill
chevybill's Avatar
My truck was originally a 6cyl 3 sped manual with 2 piece drive shaft.
I have a 350 vortec engine with a NV3500 tranny (tranny out of a99 model truck) and I was able to use my original shaft including the yoke. Engine is in the factory V-8 position.
ongoing 1970 c 10 lwb
1994 z-28 few mods.-owned since new
1978 vette silver/grey 25th anniv. paint
chevybill is offline   Reply With Quote
Old 12-03-2006, 08:54 PM   #13
Longhorn Man
all LWB trucks had the 2 pieve shaft.
Old 12-04-2006, 12:57 AM   #14
smitty62
smitty62's Avatar
Thanks for the help, guys! I had hoped to place the v-8 in the factory position, but it looks like that'll require a different shaft
Smitty
