Old 12-03-2006, 12:07 AM   #1
brak
brak's Avatar
WTB engine mounts and brake pedal
I'm currently looking for the following:
a set of V8 motor mounts in any condition.
Brake pedal assembly for an automatic pickup (truck used to have a manual tranny, with little pedal)
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 12-03-2006, 12:11 AM   #2
byrd
Union Electrician
byrd's Avatar
Re: WTB engine mounts and brake pedal
all of our year trucks have the small brake pedal, manual or not same size. The wider pedal was not introduced until 73 I believe.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 12-03-2006, 12:13 AM   #3
brak
brak's Avatar
Good to know.
Old 12-03-2006, 01:21 AM   #4
Aarons72s
I have a set out back. You are talking about the brackets that go on the frame right? I can get you a pick if you would like. And if they are to your liking how about $25.00 shipped to your door? If you want some pics pm me and i will get some tomorrow.
Aaron
Aarons72s is offline   Reply With Quote
Old 12-03-2006, 01:24 AM   #5
brak
brak's Avatar
Aaron
Yes. I am looking for the "towers" that bolt to the frame.
As long as they fit in the factory V8 position, i'll take them.
my motor is currently mounted in the Inline 6 position.
thanks
Old 12-03-2006, 01:44 PM   #6
Aarons72s
Here are te picks for you. They are ok. I got a pick with them on the old cross member and mocked up on my chassis in the correct postion. Those photos should help when you install them to as they are different for each side. Ill pm you with the rest of the details.
Old 12-03-2006, 10:50 PM   #7
4bynut
4bynut's Avatar
I should have a extra auto brake pedal setup i'll sell. And also a set of V8 mounts. I can check tomorrow for you. Thanks Jason
2007 Chevy 2500HD crew cab, 4x4, duramax w/Allison trans.
2001 Chevy ZR2 Ext. cab 4x4 (DD)
1967 Chevy SWB 4x4, BBC, Th400, NP205, 6" lift, and 35's (In Process)
1970 Chevy Blazer 4x4, BBC, TH400, NP241, 6" lift, and 38.5 boggers in front, 44 boggers on the rear ( mud racer project)
4bynut is offline   Reply With Quote
Old 12-03-2006, 11:14 PM   #8
mkhutch
Throbbing Member
Aren't those the Big Block towers?
mkhutch is offline   Reply With Quote
Old 12-04-2006, 02:08 AM   #9
Aarons72s
No they are sb towers. I pulled the sb towers for my orange and white to make sure they were correct. Yes they do look similar. I should have took a pick of the 68-71 bb mounts when I had the chance but didnt.
Old 12-04-2006, 05:13 PM   #10
454_72_4X4
454_72_4X4's Avatar
I've got a auto pedal assembly I'd trade for a stick pedal assembly.
I could,ve swore the pedal was wider than the stick brake pedal. I'll go take a second look.
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 12-06-2006, 11:46 AM   #11
brak
brak's Avatar
if it is wider, then you have a deal, otherwise i'll stick with what i have.
popular opinion states that that was one of the many changes for 73
Old 12-06-2006, 12:18 PM   #12
Shane
Shane's Avatar
The pedals are the same.
Take the clutch pedal off the assembly and you have an auto brake set up.
Shane is offline   Reply With Quote
Old 12-08-2006, 02:14 PM   #13
454_72_4X4
454_72_4X4's Avatar
Popular opinion is right. My pedal was just wrapped up in tape, (protection from media blasting), and it made it appear wider.
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
