Old 12-03-2006, 02:05 AM   #1
chevythunder33
chevythunder33's Avatar
fuel problem
Hello i installed a fuel cell and had to install a electronic fuel pump so i wanted to test the pump to see if it worked i hooked it straight to the positve on the battery to test it i never cranked the truck and oh did the pump work a buddy had came over and i forgot about the pump running for about 5 minutes and gas was going every were from the carb i assume i guess it was over flowing i guess the question is when i hook it to the ignition it should be ok? what if i turn the key on and not crank it will it over flow? any help on this would be great as i am not no mechanic buy far but i can beat and bang with a hammer and weld does that count for anything
chevythunder33 is offline   Reply With Quote
Old 12-03-2006, 02:17 AM   #2
Aarons72s
Re: fuel problem
Are you running a return line? If you use an electric pump you have to have a return line. Also is the pump self regualted or does it need an external regulator? That is important also. Hope this helps.
Aarons72s is offline   Reply With Quote
Old 12-03-2006, 02:57 AM   #3
chevythunder33
Re: fuel problem
i dont know if it's self regulated the said at autozone this is all i needed if i do run a return line were do i hook it as far as on the carb the fuel cel l said only use the return for fuel injected im lost this fuel cell as been a pain in the a$$ if it is self regulated do i need a return?
Old 12-03-2006, 03:33 AM   #4
brak
brak's Avatar
Re: fuel problem
Get a regulator (adjustable would be my reccomendation), it will provide you with a return, you will just have to run another line from the regulator back to the fuel cell, that way any fuel not needed by the carb will recirclulate back to the cell.
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 12-03-2006, 12:29 PM   #5
chevythunder33
Re: fuel problem
Ok i guess illhave to get a fuel regulator also i noticed now sense i installed the fuel pump the carb is leaking around the seal any sugestions now?
Old 12-03-2006, 01:20 PM   #6
cdowns
cdowns's Avatar
Re: fuel problem
why did you HAVE to run an electric fuel pump??i can think of many thousands of cars i've seen that had fuel cells and the good old reliable mechanical fuel pumps--- ever watched any nascar races 100% run fuel cells and mechanical pumps on thier 800hp engines// IMO running an electric pump is just looking to get youself a problem
Old 12-03-2006, 01:29 PM   #7
centsless
sufficiently talented fool
centsless's Avatar
Re: fuel problem
I agree. If you run new fuel line and it is free of any leaks, the stock pump will work just fine.
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 12-03-2006, 01:33 PM   #8
jhow66
jhow66's Avatar
Re: fuel problem
I got a electric pump on my truck with no return line . You don't need one unless it is a fuel injection with high pressure. You may need a pressure regulator if your carb needle cannot handle the pressure the pump puts out. Most electric pumps for stock fuel systems do not need regulators. What kind of pump do you have?
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 12-03-2006, 01:54 PM   #9
jhow66
jhow66's Avatar
Re: fuel problem
Here is how you should run your pump hookup to keep pump from running if engine quits: (holley part # 12-810 )
http://www.holley.com/data/Products/...l/199R9680.pdf
Old 12-03-2006, 02:46 PM   #10
chevythunder33
Re: fuel problem
i purchased a universal fuel pump from autozone i installed the fuel cell in the back under frame i hooked evrything up and the mechanical pump would not pull the gas so i installed a electric fuel pump and now nothing but problems now for some reason gas is leaking from the gasket under the carb the electric fuel pump onlypumps 5.5 to 9 psi do i need to replace the gasket under the carb now
Old 12-03-2006, 09:59 PM   #11
jhow66
jhow66's Avatar
Re: fuel problem
What kind of carb? 9 psi is to much for street carbs. No need to replace gasket as that is not your problem. Your problem is that your carb is flooding over because the float needles are not closing from too much pressure or debris under needle. Do you have a fuel filter?
Old 12-03-2006, 10:14 PM   #12
chevythunder33
Re: fuel problem
yes i have a fuel filter i unhooked the electric fuel pump and the manual pump works fine now but it is still leaking underneath the carb how can i fix this i appreciate all your help so far
Old 12-03-2006, 11:23 PM   #13
jhow66
jhow66's Avatar
Re: fuel problem
Need to know what kind of carb.
Old 12-03-2006, 11:30 PM   #14
cdowns
cdowns's Avatar
Re: fuel problem
if it's leaking between the carb and the manifold,did you try to gently tighten the carb mounting bolts?
Old 12-04-2006, 12:41 AM   #15
chevythunder33
Re: fuel problem
carter carb and yes i tried to gently tighten the bolts no luck the gasket doesnt look worn
Old 12-04-2006, 12:46 AM   #16
jhow66
jhow66's Avatar
Re: fuel problem
You have something under the float needles not letting them shut off the fuel flow. Will the engine run?
Old 12-04-2006, 01:19 AM   #17
chevythunder33
Thumbs down Re: fuel problem
yes it will run it's issing but running this electrical pump has drove me
Old 12-04-2006, 01:24 PM   #18
jhow66
jhow66's Avatar
Re: fuel problem
You need to let someone that can work on carbs to have a look at it. You have a flooding problem.
