Old 12-03-2006, 11:22 AM   #1
Imacarguytoo
Converting to Automatic
My 67 C20 2wd will be switched over to a 1/2 ton suspention...I also want to put my longtail th350 in it and remove the granny 4speed. My question is will the crossmember and driveshafts work fine with no mods?
Imacarguytoo is offline   Reply With Quote
Old 12-03-2006, 11:39 AM   #2
1969k10stepside
Re: Converting to Automatic
If you use a "long tail shaft" Th350 a different driveshaft will have to be used.67-72 trucks had a short tail shaft th350 and the four wheel drives used no tailshafts on the th350.I believe you will need a different crossmember for the automatic also.
1969k10stepside is offline   Reply With Quote
Old 12-04-2006, 08:30 AM   #3
Imacarguytoo
i dont mind shortening the driveshaft. Im more worried about the crossmember.
Old 12-04-2006, 02:49 PM   #4
Ram-Man
Ram-Man's Avatar
You will need a different crossmember. There are alot of aftermarket ones out there.
Ram-Man is offline   Reply With Quote
Old 12-04-2006, 04:25 PM   #5
byrd
Union Electrician
byrd's Avatar
You will need an auto crossmember, I have two used ones at my shop you can have one for $50 shipped, if you want a stock one.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 12-04-2006, 07:59 PM   #6
action
Active Member
action's Avatar
I am pretty sure you will have to remove the 4 spd cross member and then as others have said install an auto cross member.
Jack
action is offline   Reply With Quote
Old 12-04-2006, 08:12 PM   #7
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
The crossmember in these trucks bolts to the bellhousing.Most are riveted to the frame.You will need a grinder or some other means of removing the rivets.Depending on the tranny and crossmember you use you may need to drill holes in the frame to mount the crossmember.There should be some holes there but they may not line up with the setup you're using.Crawl under there and look at the way the crossmember is mounted.The dustcover may need to be removed from the bellhousing to see the bolts holding it to the crossmember.Good luck!!
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
