Old 12-03-2006, 06:20 PM   #1
masterbeavis
Having issues
masterbeavis's Avatar
spicer 3/4 ton hubs, HD44 being parted out
yep, partin out the axle I was trying to sell complete from my '71 K20. Price for complete axle with 4.10 gears, needs brakes and balloints $250.
PM Me if you are serious about a part.
Guess the weight of the parts and figure the shipping at the UPS website. Use 95623, ElDorado CA as the ship from address.
http://wwwapps.ups.com/calTimeCost?loc=en_US
UPS
Locking external style hubs, with blue dial. The back side of the dial is broken where the pin crosses thru it on both units. They are no longer for sale until I figure out how to fix this problem and make it a lasting repair.
8 lug outers without lockouts, rotors junk $75
Flat top knuckles $75 for the pair, ya need these for a high steer conversion
Bare loaded housing , 4.10 gears $50
Axles and stub shafts, $100 for the set.
4" lift steering arm $40
All prices are PLUS shipping, and are OR best reasonable offer. I say again, hubs as of this moment are NOT for sale till they are repaired. If you want them as is, PM me, we can work something out.
masterbeavis is offline   Reply With Quote
Old 12-03-2006, 09:39 PM   #2
LawMan02
Junior Member
LawMan02's Avatar
Re: spicer 3/4 ton hubs, HD44 being parted out
I'm interested in the Spicer hubs. Does all the internal parts come with it? Thanks, Randy
1972 GMC K2500, stepside, stock 350, 4 speed. Former F/D truck with 32,000 miles, no rust.
1973 Jeep CJ 5, 304, 33's with side pipes
2008 GMC 2500HD, CC, SWB, D/A, SLT
LawMan02 is offline   Reply With Quote
Old 12-03-2006, 11:35 PM   #3
zeusflash
zeusflash's Avatar
If Lawman02 does not buy the hubs I am interested in them. I also would like to know if they come with all the internals.I also need the left brake dust shield if you want to part with it.
'69 3/4 ton 427 CST Pickup
'71 CST Blazer
'72 GMC 3/4 4x4
zeusflash is offline   Reply With Quote
Old 12-03-2006, 11:58 PM   #4
masterbeavis
Having issues
I had planned on including everything from the hub out, making them an usefull assembly.
The dust shields come with the outers.
Old 12-04-2006, 12:44 AM   #5
Down south truckin
Down south truckin's Avatar
i'm interested in the hubs also if they get to me thanks Mike
Down south truckin is offline   Reply With Quote
Old 12-04-2006, 12:47 AM   #6
masterbeavis
Having issues
Hold onto your money.. I just finished taking the hubs off from the axle, the backside of the plastic dial is broken on both sides. I need to do some research on how to make a good long lasting repair before I can sell these.
Old 12-04-2006, 02:56 PM   #7
70rs/ss
70rs/ss's Avatar
How about the 4" lift steering arm? PM me.
70rs/ss is offline   Reply With Quote
Old 12-04-2006, 04:56 PM   #8
454_72_4X4
454_72_4X4's Avatar
Is this broken where the small metal pin passes through the plastic? It's been awhile since I've had mine apart but I drilled a new hole for the pin, (rotated the plastic slightly).
The pointer on the plastic won't line up exactly with the chrome outer ring so this wouldn't work for "show" quality but for functionality it works fine.
Hope you can make sense out of my poor description...
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 12-04-2006, 09:00 PM   #9
arkracing
Weekend Warrior
what is the differance between a HD44 and a regular 44? - just the hub/spindles - and the 8lug with bigger brakes or is the entire axle beefier than a regular 1/2 d44??
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 12-04-2006, 10:28 PM   #10
454_72_4X4
454_72_4X4's Avatar
Just different from the balljoints out. The center section is all the same.
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
Old 12-05-2006, 01:22 AM   #11
masterbeavis
Having issues
Differences I am aware of between 8 lug HD and non HD.
1. lockout style (duh)
2. Bearings are slightly larger on the HD
Differences between the 1/2t and 3/4t
1. Bigger bearings on the HD
2. Larger piston for the caliper on the 3/4t(they interchange)
3. Taller rotor
4. Rumor has it some 3/4t's have thicker tubes, and larger diameter (or maybe thats just some fords)
There were small spindles, and large spindle half and 3/4 ton.
Old 12-05-2006, 05:29 AM   #12
w314speed
I am interested in the following:
8 lug outer hubs without lockouts with the spindles and dust shields-can you knock the rotors off and throw them away $75 plus shipping AND
the axles and stub shafts- these are the left and right axles from the dif case to locking hub? $75 plus shipping
Figure the shipping to 30127 and let me know the total price. PM me payment options
Thanks, DAN
w314speed is offline   Reply With Quote
Old 12-05-2006, 06:31 AM   #13
w314speed
I wanted to ask if you have the front driveshaft from this truck? If so, $ for it
Thanks again, Dan
Old 12-05-2006, 08:09 AM   #14
arkracing
Weekend Warrior
Not trying to steal the thread on you...just trying to figure this out.
so there are 2 sizes of bearings for 3/4t axles????
or are all 3/4t (8-lug) axles considered "HD" with the bigger bearing size????
-'66 C10 Suburban
Old 12-05-2006, 12:29 PM   #15
masterbeavis
Having issues
ARKracing, I might be smoking crack on the 3/4ton bearing differences, but 3/4 ton are larger than the 1/2 ton. I think the I.D. is the same however, the half and 3/4 hubs are interchangeable.
W314: Let me separate the shaft from the Tcase, I need to check the CV and make sure its still good. Give me the measurement of your existing shaft, measured center of cap to center of cap compressed, and fully extended to confirm the size I have is the size you need. If the CV checks out, I want $100 for it.
Old 12-05-2006, 03:12 PM   #16
w314speed
I Won't Be Home Til Friday For The Measurements On The Shaft.
Let Me Know About The Other Parts In My Previous Reply.
Old 12-05-2006, 04:17 PM   #17
arkracing
Weekend Warrior
Yeh I knew that the 3/4ts had the bigger bearing than the 1/2 ton and I know that you can put the 3/4 ton spindles on a 1/2 ton axle set up.
I guess I was confused into thinking that there were 2 different types of 3/4t axles
#1. = d44 (3/4ton)
#2. = d44HD (3/4ton)
but they are the same thing and some people just use the "HD" to designate the axle as a 3/4t
-'66 C10 Suburban
Old 12-06-2006, 12:16 AM   #18
masterbeavis
Having issues
They have the HD designation from the factory
Spicer 44-5F, 44-6F Internal style locking hub
Spicer 44-5HDF, 44-6HDF, External locking hub
I searched again online and have confirmed that the HD does have a different inner bearing than a NON HD. as far as a 75HD or non compared to a '79 non. So they are not all the same??!?
Old 12-06-2006, 10:19 AM   #19
w314speed
PM sent. Thanks, Dan
Old 12-06-2006, 11:25 PM   #20
Down south truckin
masterbeavis I'm still interested in the spicer hubs even if they are broken let me know what you want for them as is thanks Mike
Old 12-12-2006, 01:23 AM   #21
masterbeavis
Having issues
Hubs will be for sale again once I have fixed the dials and aquire actuators (which these were missing) Price will be $125 for the pair, with all parts nescessary to slap these onto a bare hub. The repaird dials will be stronger than ANY NOS or used dial you will find. These wont fail like this again. The weak link is getting moved to??
Old 12-12-2006, 02:12 AM   #22
earl87gta
earl87gta's Avatar
put me inline for every thing to do an 8 lug convertion exept the locking hubs.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 12-12-2006, 03:01 AM   #23
454_72_4X4
454_72_4X4's Avatar
If ya don't mind me askin, how are ya gonna fix the dials?
I wouldn't mind refixing mine so the pointer will line up, (and be stronger too!).
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
Old 12-14-2006, 11:51 PM   #24
masterbeavis
Having issues
read it here. http://www.67-72chevytrucks.com/vboa...d.php?t=218451
