72 doors
Can someone tell me the difference between the 67-71 doors and the 72 doors?
Re: 72 doors
Easiest way is to look for a screw hole just below the vent window on the inside. 72 only option. Also 72 doors have holes drilled for christmas tree's, ie plastic door panel clips. where 67-71 use screws and weld nuts. I ll get a pic for you.
Re: 72 doors
What is the purpose of that hole?
Re: 72 doors
IIRC correctly the panels on the inside are different on the 72 than on 67-71 models.
Rottenwood Garage Member
Re: 72 doors
As mentioned above that little hole is normally a 72 thing. As far as the rest of it.....the door panels on a 67-71 are flat with big handles and the window regulator shafts are shorter. On a 72 the door panels have some deep texture and has different window regulators with longer shafts
Re: 72 doors
The hole has a screw that goes from the inner door skin to the outter, keeps the small lip that connects the 2 from splitting, which is common on 67-71 model doors.
Post Whore
Re: 72 doors
So now i have a question for you guys, can you put 67-71 door panels on a 72 if you swap out the 72 internals with 67-71 units? I want the 67-71 door panels but may be able to get my hands on a 72 door to replace my junk passenger one, just wondering if I can make it work for me
Drew '71 Chevy 350/TH350 Hugger Orange Currently just a rolling frame, body work soon to follow!!! Check out my Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=212927 Daily Driver: 1997 Chevrolet S-10 with more gears than pistons ![]() |
Re: 72 doors
You can swap them around with only minor modification--ie switch the internals.
![]() Join Date: Apr 2005
Re: 72 doors
So if you are replacing your doors with aftermarket ones, would 72's be the ones to buy??
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Re: 72 doors
Are the 72 doors in demand?
Nothings as cool as my 72
Re: 72 doors
Are chevy doors the same as gmc doors? and the differences above, are those the only differences.
1972 C10 Longbox In the middle of body off restoration Rebuilt 355, turbo 400, 3.42 12-bolt Rolling chassis finally done and cab mounted. Now onto sanding, bondo and more sanding. ![]() |
Re: 72 doors
Drew, they hardest part in putting 67-71 door panels on 72 doors is marking and drilling the bottom holes then installing threaded inserts. Other than that it is a breeze.
Hart rod- to me yes. I am not sure if the aftermarket 72 doors have the hole or not but it is a worthy upgrade. Its easier to back date a 72 door than to update a older door for 72 door panels, I ve done it cause I couldnt find 72 doors when I started my orange and white truck. 1tonswb- Yes especially if you have a 72 and dont want to buy aftermarket, it was a 1 year only door. edmonton72- Yes they are the same chevy and gmc doors. Same guidlines apply. Hope this helps you all. |
