Old 12-04-2006, 10:15 AM   #1
Chevyrod
Chevyrod's Avatar
Air ride question?
I have a 79 2 wheel drive blazer. I want to put air bags on the front. I just want to be able to pick it up for Driving. I think I am going to go with Air ride Tech's Cool Ride front kit with the 2 wheel compresser kit. Is this system good enough ? Will this sytem come with everything I need or will I have to buy more for install. This will be my first time dealing with air bags any advice will be very helpful.
Chevyrod is offline   Reply With Quote
Old 12-04-2006, 10:18 AM   #2
mkhutch
Throbbing Member
Re: Air ride question?
It seems to be a complete kit. You might need additional fittings, etc depending on how you route your airlines. I have a front Coolride kit for sale that could save you some money in the classifieds for 67-72 trucks.
mkhutch is offline   Reply With Quote
Old 12-05-2006, 06:20 PM   #3
pharcyde05
pharcyde05's Avatar
i have put on a few kits by lots of dif compays never a cool ride kit
but i have always needed someting else so it it comes compleat it would be one of the many few it seems like there is always something unexpected that you run into
pharcyde05 is offline   Reply With Quote
Old 12-06-2006, 11:32 AM   #4
craig@ridetech.com
Formerly LSC71
The parts you are looking at will get you an operating front system. We try to include everything that you will need to get the kit installed. Keep in mind that sometimes there are instances where the bolts or supplied hardware may not work for the spot you want to mount your compressor components and considering that Air Ride Tech doesn't include hardware to mount the air tank or valve block in the kits. Also you will need to come up with the power wire to run from the battery to the compressor, but other than that you should have everything you need to get the job done. With our kits you shouldn't have to call us back to buy anything else to do the install.
craig@ridetech.com is offline   Reply With Quote
