Old 12-04-2006, 05:34 PM   #1
crawdad
crawdad's Avatar
What solvent do you guys use?
Not quite sure where to post this, but I bought a solvent tank and some "water base" solvent from Northern not too long ago, and I am really put out with the solvent . The solvent came in a 5 gal bucket that you mixed with water (probably the biggest problem) and it want cut any kind of oil or grease. I've been tempted to get some regular petroleum based solvent, but the tank says to use water based only because of the electric pump. Just wondering what you guys are using and how good a job it does? Can anyone recommend a good water based solvent?
2012 Silverado LT 1500, 5.3, 6 speed auto
'86 SWB C-10 Silverado
crawdad is offline   Reply With Quote
Old 12-04-2006, 05:54 PM   #2
Billla
Billla's Avatar
Re: What solvent do you guys use?
I use Castrol Super Clean; I've been told that it's out of production, but NAPA here still carries it.
Billla is offline   Reply With Quote
Old 12-04-2006, 07:24 PM   #3
crawdad
crawdad's Avatar
Yea, I've used some of that stuff before, it works good, but I'm talking about solvent/degreaser for a 35 gal. parts washer. They don't sell it by the drum do they?
Old 12-04-2006, 07:28 PM   #4
Billla
Billla's Avatar
Drum, I don't think so - I do buy 5 gal. jugs from NAPA for my 20 gal. I use it full strength.
Old 12-04-2006, 07:38 PM   #5
84 400
Sb 400 club
84 400's Avatar
hmm can't help yeah there i know what your talking about but don't own my own parts washer. i used simple green on all my stuff but that is not what you need here gooed luck man
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 12-04-2006, 07:54 PM   #6
crawdad
crawdad's Avatar
5 gallon jugs would work. I'll just buy a bunch of them. I'll check the NAPA store out tomorrow.
This stuff works good, I know, I've used it in the spray bottle before. Still open for any other suggestions on stuff that works good men. I've had to resort to using straight gasoline every now and then, but it is tearing my hands up!
Old 12-04-2006, 07:58 PM   #7
84 400
Sb 400 club
84 400's Avatar
not to mention gas is coasting alot more these days !!! good luck in the hunt. if i was still in school i would of got the brand we used in our parts cleaner it worked great but i have since graduated years ago maybe i can give the techer a call he will know..... good luck on the hunt !
1985 C10 LWB Sold
Old 12-04-2006, 08:02 PM   #8
crawdad
crawdad's Avatar
Appreciate that 84!
Old 12-04-2006, 08:15 PM   #9
magnethead
7000 #'s of american IRON
magnethead's Avatar
We have a 55 gal parts washer, not sure what solvent we use, but my dad got it from his work in a 55 gal oil style drum. It has an electric pump.
magnethead is offline   Reply With Quote
Old 12-04-2006, 09:04 PM   #10
Mike 85
Face your fears
Mike 85's Avatar
Varsoll (sp?) if you can find it.
Saftey-Clean if you got the $$$$
Idiots like me use paint thinner.
Mike 85 is offline   Reply With Quote
Old 12-04-2006, 09:40 PM   #11
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
I went down to the gasoline/chemical distributor and they sold me 10 gallons of solvent specifically for cleaning and degreasing. Its definately petroleum based and something close to the safety kleen we have at work. It was under $20 for each 5 gallon can so it's not too expensive either.
We used to buy castrol super clean for cleaning floors when I was working changing oil. It worked ok for that, but not as well as what we replaced. We were using the safety-kleen floor cleaner that looked like tang until it got wet, then it looked just like anti-freeze. We got rid of it because people kept calling the epa on us saying we were dumping antifreeze even though we weren't.
I would advise AGAINST using Super-Clean in a parts washer. Its caustic and burns your skin pretty bad with prolonged exposure. Gloves should be used no matter what, but I don't really like that stuff for that application. It will probably eat the rubber out of the pump worse than the petroleum based stuff.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
Old 12-04-2006, 09:58 PM   #12
Billla
Billla's Avatar
Man, you know you don't want to use gas, right?
Old 12-04-2006, 10:14 PM   #13
Elsie72
Chinook Arch
Elsie72's Avatar
We used to use Varsol, then add a couple of litres of ATF in. That would keep the pump lubed, and keep from drying things out with straight varsol. We'd use a gallon of water, too. One of the old tech's said that the sediment would settle to the bottom with the water, and extend the life of the solvent.
1972 GMC 1500 Custom - Bought used by Grandpa in '74, currently back on the road after a long hiatus.
Elsie's truck
2.5" dual exhaust with Hooker Aero Chambers
Holley 670 Street Avenger Edelbrock Performer RPM on GMPP 290HP 350
ECE drop 3.5/5
Elsie72 is offline   Reply With Quote
Old 12-04-2006, 10:29 PM   #14
Billla
Billla's Avatar
Um, you're saying Super Clean is worse than a petroleum-based solvent? Can't see it. I've had it in my Harbor Freight 20 gal parts cleaner for 5 years...so if it's going to eat the pump it should start sometime soon ;-)
Old 12-04-2006, 11:13 PM   #15
ElGracho
ElGracho's Avatar
For rubber yes. If they are worried about petroleum eating seals and recommending a water based product, then they are probably talking about rubber and the caustic in super clean would be worse than the petroleum solvent.
As far as your harbor freight cleaner, I have one of those too. They probably don't use natural rubber in the pump for seals for just these reasons...
Here's a link to the National Institute of Health page on the stuff: http://householdproducts.nlm.nih.gov...nds&id=3011002
Here's a link to a castrol data sheet: http://www.castrol.com/liveassets/bp...loads/k/kk.pdf The 1-5 % Sodium Hydroxide is what makes it caustic or corrosive (>~7.5 pH). It has a pH of 11-13, that will make it eat natural rubber in a heartbeat.
Most petroleum cleaning solvents (those made to be solvents, not gasoline or paint thinner) are much closer to neutral pH and do not attack rubber.
Joe
Old 12-04-2006, 11:47 PM   #16
Southedisto
River life......
Southedisto's Avatar
Simple green, if you can find it.
Southedisto is offline   Reply With Quote
