Old 12-04-2006, 06:26 PM   #1
chadvicki
Color Sanding
Hello,
I am need of getting my truck color sanded. It is a white truck with a recently new paint job. However it sat out in the elements for some time. It has no dents or scatches but the paint just has some yellowing on the flat surfaces such as the hood and so on. It also has a flat kinda not smooth like glass finish.
Anyway I was told by the previous owner to have it color sanded and it would be like new and shine shine shine.
So my ?? is what does it involve and what do I look for in the place that will be doing the work.
Thanks,
Chad
P.S. I am in southern california if anyone knows a guy around here.
chadvicki is offline   Reply With Quote
Old 12-04-2006, 06:44 PM   #2
Myself
Re: Color Sanding
That all depends on whether it's single stage or B/C. If it's single stage, wetsand the whole thing with like 1500 grit then buff it back out. If it's clearcoated and yellow looking, I'd say all the clear needs sanded back off and redone.
Myself is offline   Reply With Quote
Old 12-04-2006, 06:45 PM   #3
chadvicki
Re: Color Sanding
Is there a way to know if it has been clear coated?
Chad
Old 12-04-2006, 07:29 PM   #4
SactoJim
SactoJim's Avatar
Re: Color Sanding
If it is not clearcoated the color of your vehicle will show on the buffing pad and when you color sand the water will appear the same color as well.............might be a little harder to notice with White.
If you paint job appears to have gone flat and/or chalky, I would say it is more then likely a single stage paint (no clearcoat). If that's the case, I would just start with buffing and stay away from the color sanding.
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 12-04-2006, 08:50 PM   #5
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Re: Color Sanding
My Jimmy did the same thing when it was white, from chemical de-icer the city applied (SF,SD). I buffed it off in the spring, but I didn't pay attention when I sanded it for the new paint job if it was single or base/clear.
Hope this helps a little.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 12-04-2006, 09:38 PM   #6
chadvicki
Re: Color Sanding
What would be a good buffer? I have never buffed a vehichle. I have waxed one . Should I get one of those rotating tools?
Chad
Old 12-04-2006, 10:11 PM   #7
72CSTC5
72CSTC5's Avatar
Re: Color Sanding
Get a piece of sandpaper and sand it dry. Use 1500 or 2000. Look at your paper and check to see if it is bright white or medium white. If it is bright white than it is single stage. Medium white than most likely base clear. Orbital buffer will not buff out a sanded paint finish, you need a high quality RPM selectable (preferably) buffer. Be careful if you have never done before, you can mess up some paint.
72CSTC5 is offline   Reply With Quote
Old 12-04-2006, 11:57 PM   #8
Imacarguytoo
Re: Color Sanding
Once you figure out what paint you have. You can rent a buffer from a rental place and the pads. First wet sand the paint with 3000 grit wetdry paper. KEEP IT WET and use a couple drops of DAWN dish detergant in the bucket of water.
Be very carefull around edges and use a slow speed on the buffer. DO NOT push on the buffer thinking the harder you push the better the shine, not the case. Let the weight of the buffer do the work and use your hands to just control the buffer. ALso when you wet sand do 1 panel at a time bevery careful around the edges of fenders and so on. Pretty much at the edge of the body panel. Get a buffing compound call Perfect it 3 from 3m. You can get that from a paint and body supply store as well as the wet/dry paper. Put the compound on the pad and start slow and do half a body panel till the compound is worked in to the paint. Buff back and forth and keep the buffer moving or you will burn the paint. Buff till you have a nice shine and the sanding marks are gone. I would go to walmart in there paint department and get a small VERY flexable plastic pad or something to wrap the sandpaper in so yu dont get finger marks in the paint while sanding. Remember keep the paper SOAKED.
Use a lamswool pad first then move to a foam pad for the perfect shine. Keep buffing till all the sanding scratches are gone. After the complete vehicle is wet sanded and buffed use some meguiers wax to protect the paint. Heres some pics of it done on my drag truck. This was 11 yr old factory clear coat paint. If you have any questions email me at imacarguytoo@yahoo.com
Imacarguytoo is offline   Reply With Quote
Old 12-06-2006, 12:33 AM   #9
chadvicki
Re: Color Sanding
Ok, I found out I have a clearcoat on the paint. I went to a dealer and he did a small portion on my car and it was smooth as glass. However I can not get rid of the yellowing since it is under the clear coat.
So now I have to see if it is worth the $450 for color sanding a badddd pearl attempt paint job, butttttt smooth like glass. OR leave it the way it is, OR get e new paint job for around $1000 bucks.
What kind of paint job can you get for around $1000???
This is a daily driver with a perfect body and straight. So I just need a paint job no body work.
Thanks,
Chad
Old 12-06-2006, 04:04 AM   #10
chadvicki
Re: Color Sanding
Old 12-06-2006, 09:03 AM   #11
Imacarguytoo
Re: Color Sanding
I am sure there are mixed emotions on this BUT ive seen on a handful of cars of a friends. I would take it to maaco or a similiar paint shop in your area. If i remember right there paint jobs start at 300.00.
SOrry to hear about the paint. But you will get it lookin good sooner or later.
Old 12-06-2006, 11:29 AM   #12
brak
brak's Avatar
Re: Color Sanding
personally i have never seen a good paintjob come from Maaco.
Although Last months issue of truckin, was promoting the hell outta them, I am a firm believer that you get what you pay for.
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 12-06-2006, 11:54 AM   #13
texascowboy593
texascowboy593's Avatar
Re: Color Sanding
You do get what you pay for... My 71 was done @ Maaco for a few hundred and its only OK. It is chipping in a few places and dosen't stand up well to door dings and scratches but... at the time that was what I needed. Its a daily driver that will get me by for a few more years til I really Re-do it! Even though its not perfect I still get compliments on it...
"The rays of light thru the Shiner Bock bottle make me wanna turn the key and put down the throttle...and get lost down 35" - Jason Boland
www.YouTube.com/user/593Films - Watch My Videos!
1977 Silverado K10
2014 Dodge Durango (Wife-mobile)
2008 Dodge Ram Lone Star Edition (Daily driver)
texascowboy593 is offline   Reply With Quote
Old 12-06-2006, 05:30 PM   #14
JRB
JRB's Avatar
Re: Color Sanding
Hello Chad,
I will start by telling you I am no expert but I live across the street from a guy that restores and paints old GTO's (SHOW CONDITION) and I have been mentored by him and one of the first things he taught me about buffing is which way to manipulate the wheel when your buffing in correlation with the surface your buffing. If you haven't done one before I would suggest you pay the money to have it done and watch very closely how the guy buffing it manipulates the buffer. You can burn paint and leave nasty marks in your paint if you dont do it right. I wish you luck with your project.
JRB
JRB is offline   Reply With Quote
Old 12-06-2006, 06:26 PM   #15
nutsforchevys
nutsforchevys's Avatar
Re: Color Sanding
I use the perfect it 3 from 3m and it is amazing. I finally broke down and bought me a good buffer from the paint store it cost around $90.00 but was so much better than the cheapo I used to have.
72 Super Cheyenne lwb 4X4 Ocra / White
88 Chevy 1 ton Dumptruck
88 Chevy 1ton Flat bed 4X4 white
nutsforchevys is offline   Reply With Quote
