Old 12-05-2006, 01:20 PM   #1
Roland
Junior Member
Roland's Avatar
Smile Need Spring Info
Membership to this board is the best buy I've found! You folks are all great.
I want to lower my '68 Step Side - "just so I don't see so much above the tires", kind of lowered. I am really leaning toward 4" drop coils at the rear, and 3" drop coils at the front. I am sure someone has done this and I'm wondering if there might be a picture or two that someone could post.
I looked through FAQs and didn't see what I was lookiing for.
Thanks!!
Roland is offline   Reply With Quote
Old 12-05-2006, 02:12 PM   #2
bryanw1968
bryanw1968's Avatar
Re: Need Spring Info
Hey Roland,
I have a 2/4 drop on my '68. I got my springs from EarlyClassic and I'm very pleased with them. They lowered my truck but retained the ability to still haul stuff and actually use it as a truck. A buddy of mine got some springs made overseas somewhere and they are pitiful. Just standing in the back almost bottoms the bed out.
Check out my truck....
bryanw1968 is offline   Reply With Quote
Old 12-05-2006, 04:51 PM   #3
Ram-Man
Ram-Man's Avatar
I would use drop spindles in the front to get your drop. From what I have read this is how most prefer to drop the front.
Ram-Man is offline   Reply With Quote
Old 12-05-2006, 05:26 PM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Using drop springs in front requires realignment.Usually this means a fairly large shim pack.Most shops don't like to use lots of shims and most suspension people don't either.There is a sense that a large shim pack means the bolts are longer and have more leverage thus making broken bolts a possibility.Even though spindles are more expensive you can also upgrade to disc brakes with them.There are several ways to go about this and most have threads in the FAQ section.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 12-05-2006, 05:48 PM   #5
bryanw1968
bryanw1968's Avatar
Spindles are really the right way to go. I just didn't want to get stuck with drop spindles. I wanted the ability to go back up if for any reason I wanted to raise it. Silly me
Old 12-05-2006, 05:58 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
bryanw1968, that sucker looks sweet... you gonna stick with the blue?
Old 12-05-2006, 06:06 PM   #7
bryanw1968
bryanw1968's Avatar
Thanks man!
I actually like the color. It's sorta blue/green. All my buddies call it teal which really pisses me off
Actully for now since I don't have much time I'm going to fix a coupla rust spots and just flat it black until the summer. Then I'll try to paint it.
Everything else on it is done though. Motor, trans, suspension, disc brake conversion, glass, wheels....etc
