Old 12-05-2006, 01:51 PM   #1
dave2953
Dave's not here, man
dave2953's Avatar
Shifter Question
My truck's shifter is nearly impossible to move when it gets cold out. It's a column shift, and when it's warm out it pivots freely. When it's cold out you can't really move it at all. I thought it had something to do with the pin that holds the shifter in place, but that didn't seem to change anything. I don't know much about the internals of columns and was hoping someone could help me. Thanks!
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 12-05-2006, 02:18 PM   #2
Critter
Future TOTM Winner
Critter's Avatar
Re: Shifter Question
What do you mean by "cold", 30-40deg? I had an old 3 speed whose linkage and internal column parts were covered in old nasty grease. If yours is the same, it might be gummed up on the moving parts, and when things warms up, the grease becomes thin enough to move freely. Just a thought
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 12-05-2006, 05:41 PM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
dave,I have had this problem before.I suggest the following.
(1) Put a quart of oil in the truck(Leave it in the bottle)
(2) Get a pocketful of quarters
(3) get a can of degreaser and one of WD-40
(4) Cruise down to the car wash
(5) Cover the igbition system
(6) Spray the column and shift levers down with degreaser
(7) Wash the rest of the truck
(8) now the degreaser has had time to work
(9) Cleand the column and levers with the spray wand
(10)Spray the shifter assembly with WD-40
(11)Now pour a little oil in the working areas of the shifter.
(12) work the shifter thru the gears several times
(13) Stop at the parts store on the way home and pick up new bushings for the lower end of the shifter arms
(14) install the new bushings(make sure to lube them)
You may need to repeat this every 2-3 years or more often depending on where you live and drive.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 12-05-2006, 06:01 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
na, his is an automatic.
I fought with that crappy shifter and said screw it, I went with a van tilt which has a wonderfully more modern shifter set up. You can pull the steering wheel, the turn signal and then get to the shifter bell or what ever they call it... the part that rotates on the column, where the shifter arm is hooked with that pin that you replaced, and then clean everything, and coat it all with anti-seize compound.
Old 12-05-2006, 06:03 PM   #5
cdowns
cdowns's Avatar
auto or manual
just amazin what some cleanin and lubein will do
Old 12-05-2006, 06:28 PM   #6
Critter
Future TOTM Winner
Critter's Avatar
Auto or manual, the above advice will do wonders. If you can get inside the column and do the same cleaning/re-oiling procedure you will feel like you are shifting a brand new truck!
Old 12-05-2006, 10:16 PM   #7
Longhorn Man
his signiture says powerglide...auto.
Personally, I have never seen one of these style collumns bind at the bottom (automatic) but every single one I have ever shifted.... to include 75 or so p/30 trucks we were rebuilding at work, was binding at the top.
Old 12-06-2006, 01:49 AM   #8
Critter
Future TOTM Winner
Critter's Avatar
I wasn't asking which trans he had, I was just commenting that either way, "auto or manual", a good scrubbing will do it alot of good. I agree about the top of the column binding. In the autos that I have seen, the inner shifter tube doesn't move freely inside the column housing. Sorry about the confusion.
Old 12-06-2006, 02:17 AM   #9
dave2953
dave2953's Avatar
Thank you all very much for the replies. Hopefully I'll be able to get out tomorrow and mess with it.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
Old 12-06-2006, 06:26 AM   #10
Longhorn Man
no problem critter... I should have caught that actually.
