Old 12-05-2006, 02:59 PM   #1
BowTieOgre
Brake woes
I checked briefly via search but no luck so I figured I would ask. My '73 Blazer I recently bought was pulling to the left during braking. While I was changing the fluids, filters, etc. I went ahead and installed new rotors and pads as well as cleaned and repacked the bearings. The passenger side pad was almost nonexistant and the rotor was grooved beyond belief. After I installed the new parts, bled the brakes and topped off the fluid it STILL pulls to the left during braking. I smelled a slight burning smell eminating from the right front wheel today and the wheel and center cap are really hot to the touch while the other side is not warm at all. Any ideas?
Im going to take the wheel off when I get home from work today and take a look.
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 12-05-2006, 03:58 PM   #2
neonlarry
neonlarry's Avatar
Re: Brake woes
It could be a bad brake hose (the rubber portion).
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 12-06-2006, 11:35 AM   #3
craig@ridetech.com
Formerly LSC71
Re: Brake woes
The piston in the brake caliper could be sticking. I had a 71 that had the same problem. I went ahead and put on 2 new calipers and fixed the problem.
craig@ridetech.com is offline   Reply With Quote
Old 12-06-2006, 01:13 PM   #4
st1x10
st1x10's Avatar
Re: Brake woes
Brake hose is probably expanding. Check the opposite side of the pull. Also the Caliper might be sticking however that is less likely.
1970 Chevy C10 "Under Construction"
2002 Chevy S10 V6
st1x10 is offline   Reply With Quote
Old 12-06-2006, 03:48 PM   #5
BowTieOgre
Re: Brake woes
My garage is full of the project '70 parts and by the time I get home daylight is gone so no chance to pull it off yet. A friend of mine from work who is mechanically inclined suggested a new caliper as well. Thanks for the input all!
Old 12-08-2006, 05:23 PM   #6
pharcydekm
Re: Brake woes
Replace both Calipers. Odds are if you do just one side it will pull the opposite direction. Just my .02 but kinda like shoes by two at a time.
pharcydekm is offline   Reply With Quote
